Computers & Internet Logo
Nelly Razo Posted on Dec 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The path to remove background button is - Computers & Internet
max carson
Level 3:
  • Master 7,627 Answers
  • Posted on Dec 13, 2013
max carson
Master
Level 3:
Answers
7627
Questions
Helped
1014207
Points
21773
A bit crypt? Can you rephrase the question? Make , Model of Laptop, the OS you are using?
Black background when scanning in greyscale
There is an option to set the brightness/contrast in the first page of Capturperfect. Select automatic if you cannot manually set it.
S. Mohan
2answers
Panu mag edit ng picture
1st download bittorrend software and install it on your pc
http://www.bittorrent.com/btusers/download/complete?os=win
2nd click below link it and on the page click on " DOWNLOAD THIS TORRENT"
a window will popup click "OPEN". automatically bit torrent software opens. select the path to save in bittorrent software. wait till the download. and locate the file and install. enjoy...
http://thepiratebay.org/torrent/4082251
2answers
How do you upload pictures and use them as a background on memorex Label Maker? I went to the browse backgrounds and yet all there are are default backgrounds and I can't upload my own
It will automatically default to default background directory. When the default directory opens look up top and there will be a browse photo button. Click on it and then choose C: drive and then the directory or folder your pics are in.
1helpful
2answers
How to put a background pictures on my acer aspire one windows 7
find the photo (from internet,store on pc or flash drive) you like to have as background (its called wallpaper)...see the file /photo right click on the photo save as wallpaper...apply...you are done
2helpful
2answers
Background changeover unit failure on 6130dj scanner. Tried cleaning it, rebooting pc & downloading driver . . . what else can I do?
When a background switching malfunction occurs, "F" and "4" will display alternately on the function number display panel of the scanner.
Wipe the top and bottom glasses located inside the ADF with the Cleaner F1 and check if the problem persists.
If turning on the scanner again does not recover the situation, then follow the procedures provided below:
1 Does the same symptom occur after turning OFF and ON the scanner? Press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2 Are the cables between the Control PCA and the BW Motor damaged? Or are the connectors connected correctly?
3 Is the white reference work properly? If not, then replace the BW Motor.Perform background changeover test.
4 Is the OPT Unit installed correctly? Check ADF (Front) and ADF (Back)
5 Replace the Control PCA and see if the error is resolved.
6 Replace the OPT Unit and see if the error is resolved.
Hope the above information is helpful.
Thanks,
ScanCare
When I scan a document with a white bacground, it prints with a light grey background.
This is a fairly common problem with copiers. It is usually caused by a dirty optical path, an overtoned condition, or failing developer. If you are qualified to do so, I would say clean the optical path by removing the glass and cleaning the underside of the glass and all the mirrors.
Canon Dr-2580C
Try and scan a white paper. If the output is black, then may be the LEDs are not glowing, likely the wire is loose. Actually it is not easily reacheable! Try duplex scanning to check if both scan modules are fine.
S. Mohan
E-mailing
Add Background Sound to an Email in Outlook
To add background sound to an email in Outlook:
  • Create a new message using HTML formatting in Outlook.
  • Download the following file to your Desktop: zbgsound.htm.
  • Start Notepad.
  • Open the zbgsound.htm file you just downloaded in Notepad.
  • Replace ###path to background sound file### with the path to the desired background sound file.
    • The line could read <img src="C:\Documents and Settings\lsdoe\My Documents\My Music\lsdoem.mid" id="bgsound", for example.
  • Select File | Save from the menu.
  • In the Outlook message, select Insert | File... from the menu.
  • Go to your Desktop.
  • Highlight zbgsound.htm.
  • Click on the right down arrow of the Insert button.
  • Select Insert as Text.
  • Continue editing your message.
Source:
http://email.about.com/od/outlooktips/qt/et071705.htm
I hop that helped, it looks complicated buts its not. Basically if you know how html works your email allows html you just put the html code for teh music in it.
Good luck,
Cam
Grand Canyon Tech
Grand Canyon Tech
