HI, I want to upgrade ios on 3825 router. While i was backing up to tftp server, i notice it has 2 ios. Now i am confused. Does it need 2 ios. If not then why its there and what can be reason behind it? I want to practice my security certification course on this. which ios recomended for CCNA & CCNP security track? Thank you.
PASS CCNA/CCNP security is exay if you choose SPOTO.
Best IT Certifications Online Exam IT Certs Dumps Questions Answers...
Hi Ian,
Current flash has the capacity to store multiple IOS files. You shall keep different versions of IOS into the flash and using boot var you shall configure the router to boot from specific IOS version Something like dual boot OS in your Laptop. You shall use Cisco IOS 15.3 (M,T,ST) for your CCNP Security certification preparation. For furhter details regarding IOS selection you shall use cisco ios selector tool share in link section. http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/index.jsp
SOURCE: auto backup IOS of router.
If you want to back up your Configuration on any Cisco Router, You can just use RANCID (http://adi-sunardy.net/2008/12/24/how-to-automating-cisco-router-switch-firewall-backups-on-fedora/).
Or, some other solution:
Or follow these instruction: http://www.techexams.net/forums/ccna-ccent/22447-how-setup-tftp-server-backup-restore-2500-ios.html
Or You can read this: http://blogs.techrepublic.com.com/networking/?p=532
Hope it'll help
SOURCE: Looking 4 a TFTP server for upgrades
There must be a tftp server on your network, that must have files on the server that are needed top upgrade the firmware. Ask your admin, as they will have the IP address. I can refer you to a tftp program you can install on a server, if need be.
SOURCE: I HAVE ROUTER CISCO 2503
For Software Order.
To order an upgrade, please use the product numbers beginning with "FL". These product numbers, known as Feature Licenses, enable your order to be processed as an upgrade and not as a more expensive new-system purchase.
Ordering Example
•You are running the IP feature set (S25C-12.0.1) in a Cisco 2500 series router •You want to upgrade to IP PLUS (S25CP-12.0.1) Use FL25-P= to order (see the price list for all available product numbers) •You want to upgrade from the IP feature set (S25C-12.0.1) running in a Cisco 2500 •You want to upgrade to the IP/IPX/AT/DEC PLUS (S25BP-12.0.1) feature set You must use two Feature Licenses: •One to upgrade from IP to IP/IPX/AT/DEC (FL25-C-B=) •One to add the PLUS (FL25-P=) For Upgrading Procedure Please check the below link. The procedure is for all the Cisco Router
Example 2: A Complex Upgrade Order
More than one Feature License may be required in ordering an upgrade.
Ordering Example
