At first if i did 4+4 it gives me 8.000000000x10o, now it gives me 8.0000, after reading an answer to move it to dec. places, but how do i get it to normal settings?! thanks!
SOURCE: how do i get the answer of a simple arithmetic in decimals?
There is a button there that says "S<=>D". Compute it first and when the result is in fraction, press this and it will be in decimals. This button is just above the DEL button.
SOURCE: Hi, I have a Casio calculator fx-991MS giving me wrong answers!
I am only looking for a plausible cause of the error, because I do not believe your calculator can make such a mistake. I think you accidentally activated the Exponential display format and did not pay attention to the small, raised -03 that came at the end of the number displayed. It is a common mistake for those not very familiar with Scientific or exponential notation.
Let us try to reset your calculator to the normal (floating point) format.
Press the [MODE] key a number of times until you reach a screen that has FIX, SCI, NORM and under each one a number (FIX 1, SCI 2), Norm 3). To have the number of decimal place you gave in your result (4 decimal digits), you press 1 to select Fix then 4.
Be aware that scientific calculators usually stop displaying results in floating point format ( 0.0000045 ) if the number is smaller then 0.001. So basically, 0.00099 will be displayed as 9.90-04, -04 being raised above the level, and in smaller size.
Hope it helps.
Testimonial: "Thanks so much, its working now:) I thought I was going to have to buy a new calculator!"
SOURCE: FX-55 Calculator: how do I clear my casio scientific calculator from...
press the "MODE" button 3 times and then press 3 ..., now this is normal mode
SOURCE: I have a Casio FX83ES
1÷1700 expressed as a decimal is 0.000588235, which is 5.882...×10^-4. [NB not 10^4]
To convert this to a percent, remember that "per cent" means "per 100" which also means "divide by 100". To keep the answer correct, if you are dividing by 100 you must also multiply by 100.
The get the answer in percent, you must therefore multiply the previous answer by 100 to get 0.00588235 percent. (or 5.882...×10^-2 percent).
