Our Bosch WTE84122BY Condenser Tumble Dryer dosen't starts: start/stop and dryng selection mode lights are
Hans Thanks!
it worked like a charm!
You saved me around 100$
Aitan
Did you check the res to see if it was full? Might be clothes inside the door and it aint shut all the way? never even seen a condenser dryer.
I have the model service manual though HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: water tank full (!) in bosch tumble dryer WTE86301gr
As a matter of fact I have solved the problem. The dryer is now fully functioning again. :-)
I'll try to explain how to fix the problem:
The water that condenses in the condensor (doh!) drips down into a container situated below the condensor. The moist air that passes through the condensor is the same air that circulates via the clothes, thus it also contains some lint that the filter doesn't catch. Over time there will be some build-up of lint and mucus (?), clogging the tank AND a sensor that sends a signal to the electronics to start the pump that evacuates the condensed water to the removable tank in the upper part of the machine. This messes up the function of the water evacuation system.
Alright, pull out the condensor and find a hatch in the 'floor' in the farther part of the compartment. Below the hatch you'll find the container that collects the condensed water. Start by cleaning it as thoroughly as you can. There are a few 'nooks and crannies', take your time, also flush with some fresh water and maybe some gentle cleanser to get rid of the mucus. The pump and the sensor for the pump are located in the left part (viewing from front of the machine) of the container. Try to flush there as well.
If this procedure doesn't solve the problem you'll have to disassemble the machine to also be able to remove the pump and sensor housing. I had to do this on mine. Quite a few screws to remove and keep track of, but pretty straight forward if aren't too uncomfortable with 'fixing things'.
I have some pictures of the 'project' somewhere, let me know if you would like to see them or if I may help you some other way.
BR /Hans
SOURCE: I have a Bosch Maxx condenser tumble dryer that wont work.
Have you taken the condenser itself out from the bottom of the machine? Remove the condenser from the bottom door and rotate the clamp tags which secure it in. Slide condenser out (aluminium mutli-finned box assembly) and carefully take it outside. Use a garden hose with lots of water pressure to spray each vent passage carefully to clear lint and dust away. Passages must be cleared in both directions, long ways and cross ways. Cross ways is the problem area and once you finish clearing the air ways you should see daylight through the condenser easily. Reassemble and always clear lint filter in the door /drum area.
Good luck.
Sam
SOURCE: Our Bosch Classixx Condenser Tumble Dryer works
my wte84105gb condenser dryer (bosch) as a symbol on it looks like a glass with wavey lines inside it will not dry please advise what to do .
SOURCE: My tumble dryer WTE84122BY keeps switching off
http://laundry.manualsonline.com/manuals/mfg/bosch/maxx_wtl_6500.html?idRes=274378
click this link you will find dryer manual in english
SOURCE: Bosch maxx 7 condenser dryer not working after power surge
Most likely, the surge blew the internal fuse. I would try replacing that first. If you can't do it personally, have a certified tech do it for you.
