FH is Fill Hose error. Turn off water supply and disconnect hoses from back of machine, clean off strainers on back of machine where hoses connect and make sure you have water coming through hose. ( you can turn the water on slowly one hose first then the other and catch the water in a pot or mop bucket. You should have a steady water flow.) hook hoses back up, turn on water and test.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within a1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear foe several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
