2003 Dodge Durango Logo
Posted on May 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Loud humming noise from front end of Durango 4 x 4
Loud humming noise coming from front end, no play in wheel when jack up on either side. noise stops when turning right/left. noise get louder with speed. all other area around tires seems fine.
  • Anonymous Mar 19, 2014
    when start to drive, I hear a noise in the front wheel drive, left side
Anonymous
Level 3:
  • Master 253 Answers
  • Posted on May 13, 2009
Anonymous
Master
Level 3:
Answers
253
Questions
0
Helped
148817
Points
1114
You have a hub/wheel bearing going out. You need to jack up the vehicle on each side. Grab the top and bottom of the wheel and try to move it in/out at the top and bottom. If this does not work then roll the wheel as fast as you can and see if you can hear which one it is. Good Luck.
MY 1998 FOR EXPLOYER ELT HAS A LOUD HUMMING NOISE THE FAST I GO THE LOUDER IT GETS CAN ANY ONE TELL WHAT A POSSIBLY CAN BE .MY HUSBAND SAYS THE SPINDLE????
Humming Noise Front End- Any Ideas? - Ford Explorer and Ranger ...
www.explorerforum.com > ... > Stock 1995 - 2001 Explorers
Dec 18, 2008 - 19 posts - ‎16 authors
Have a 98- Eddie 4.0 SOHC, 4WD with a 100,000 mi. When driving it has a humming noise, it almost sounds like a bad tire, or a ... I start to hear the humming noise at 20 mph, it is very loud at 40 to 50 mph ... 94 XLT-95 FX4. humming gets louder as speed increases
May 27, 2010
How to: IAC valve cleaning thread (w/pics)
Oct 29, 2007
humming from air intake
Jun 6, 2002
Loud humming noise coming from the air filter
Oct 6, 1999
More results from www.explorerforum.com
It is making a humming noise
Does it change with vehicle speed or engine rpm?
vehicle speed: check wheel bearings lift vehicle and support it with jack stands grab the wheel at the 12 and 6 o'clock positions( to rule out steering linkage play) and wiggle in and out. A bad bearing that loud will have some play.
Front end makes loud noise while driving over 10mph and gets louder and hums down when i stop
It sounds like you may have a wheel bearing/ hub assembly starting to go bad...You can check this by jacking up the front end and checking for slight play in each wheel when you try to move tire in a side to side,and up and down motion basically But you just want to use a wiggle motion...you should be able to feel a bit of excessive play in the side which is going bad...One side will be tight with no play,and the other will have some play if the wheel bearing hub assembly is going bad...
4helpful
2001 dodge durango 4 wheel drive not working loud knocking
You need to check the cv joints in the front end or the u joints in the front drive shaft.If none of the above then the problem is internal in the front diff.
2helpful
Loud humming noise from drivers side front end changed hub assembly still have noise ????????????????
humming noise usually comes from wheel bearings. did you change that with a new bearing? also choppy or worn tires can cause humming noise that sounds like bad wheel bearings. rotate your tires and see if the noise changes. if so its tires. also even if it sounds like its from the right it could very well be a bad bearing in another location.
1helpful
When driving at low speeds and turning
COULD BE THE WHEEL BEARING WORN. JACK THE WHEEL UP AND MOVE FROM SIDE TO SIDE LOOKING FOR EXCESSIVE PLAY AND SPIN THE WHEEL CHECKING FOR ROUGHNESS OR TIGHTNESS IF YOU HAVE THIS ITS THE WHEEL BEARING.....IF IT IS MORE LIKE A CLICKING OR KNOCKING NOISE WHEN DRIVING IT WILL BE A CV JOINT.TO TEST, DRIVE AT SLOW SPEED ON FULL LOCK AND YOU WILL HEAR IT.....IF THE SOUND IS COMING FROM THE ENGINE IT WILL BE ONE OF THE PULLEYS,(TENSIONER OR WATER PUMP) BUT IF IT IS THAT, YOU SHOULD STILL HEAR THE NOISE WHEN YOUR STOPPED (REV THE ENGINE A LITTLE) AND IF THERE IS NO NOISE ITS NOT COMING FROM YOUR ENGINE THEN......HOPE I WAS OF SOME HELP TO YOU..HAVE A NICE DAY.!!!!
2answers
2001gmc sierra 1500HD have a loud humming noise
It could be many things. Poorly balanced tire comes to mind first. If it was static balanced and not high speed balanced that is
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
