This is what you need http://get.adobe.com/flashplayer/
Its completely free, but after done, just restart your browser which you use to open up websites and it should work. Hope this helps :)
If your truck is overheating,it could be a coolant leak, a coolant hose that is collapsing, a thermostat that is not opening and allowing the coolant to circulate, if your check engine light is coming on take it to an autoparts store like auto zone or advance autoparts where they can scan the cars computor and determine the cause of the overheating, places like this will not charge you for the scan. good luck!
Yes your batteries have dropped below 9 vlt each and they wont chage using your charger. Yuo must take a car battery charger and charge each battery up to at least 11vlts for your charger to charge! This ought to work if batteries have only been sitting a couple of mths . When using a car charger set charge at 6-10 amps for about 45mins to 1hr then hook up chair charger and you should be ok
Hello Sir,
If the battery is showing low battery then you should charge it with its corresponding Charger. I think you are willing to tell that the Phone is showing low battery even after charging. If that is the case then there can be 2 causes :--- (1) The Phone's battery is not properly plugged in and thus can't properly retain the Charge which is supplied. In this case, try cleaning the Battery Contact, I mean the 3 Power pins and the 3 power slots. Use something like dry cloth. (2) The Battery is damped or defective. If damp then don't try to charge, it can sometimes explode. Kindly take it to a Service Center and get it repaired.
Also try changing the Battery.
Thank you Sir, Have a nice day.
Have you got the right charger?? if yuo dont have the right charger for you mp3 player it may not charge the way it should i would recommend changing the charger or the cable.
firstly, it could be a power supply issue. check the voltage on your battery. it should read about 12-13.8 volts and if you can get a cold cranking amps tester that haelps too, it should put out at least 250-300CCA. If it isn;t then yuo have either a bad battery or a bad alternator, not charging the battery sufficiently. more testing.
If these are ok then yuo may have a damaged solenoid or starter motor. the clicking spound is the solenoid, this is like a high current electronically operated switch that pushes the pinion gear on the starter into the large ring gear on your flywheel. at the sdame time as closing the circuit between battery and starter. your best bet is simply to take it to an auto-electrician if this is the problem.
Some causes: i have had bad starter motor experiences myself. recently, i had to ghave my starter replaced because i had allowed the solenoid to become creammed with mud and not washed out properly. this ceases the mechanism up
essentailly, you need to get creative in finding a way to open the hood to check things but if you can't then you can still check the battery voltage through the cigerette lighter socket being careful not to short the terminals as this will cause the annoyance of a fuse blowing. easy to fix, but annoying. good luck!
