It appears the door handle isn't releasing properly so the door won't latch. Nothing appears to be blocking the mechanisms, though.
SOURCE: Detergent dispenser will not stay shut so the soap
Opening the door did not affect the latch on the dispenser. The catch does wear out and can be replaced. This involves disassembling the door and a small jigsaw puzzle of springs and levers. If you are attempting I would advise taking pictures to refer to before taking apart.
Eric
SOURCE: door won't close
you will need to replace the strike and the catch. you can try adjusting it but that probably wont work.
SOURCE: kenmore dishwasher latch malfunction
if you just bought it should be under warranty. call for service. if not under warranty replace the latch assembly. you can also remove the console that holds the latch and see if there is an obvious reason for the binding.
SOURCE: need to find door handle latch for kenmore dishwasher 154355101
THAT IS WRONG MODEL NUMBER THERE IS MORE NUMBERS..
When you get correct model go to searspartsdirect.com and you can order yourself.
