CE
Communication error
If communication between the ignition board and the display board is not established within 3 s of power-up an error will be displayed. After communication is established, if it is lost for 30 s, the error will be displayed. The error code will be cleared upon a valid data exchange between boards
All you can do is remove the panel and make sure that the connection between the two boards is good and dry. Other than that, you will be changing cable from the lower board or the lower board itself.
028 Error is a coax com error, check your cable, system and printer interface. If all good you might need a new interface card for your printer. I have in stock.. Rory 708-597-4222
An 028 error is a Coax Com error. Might want to check your coax line, or system. If all seems good might need a new coax interface installed on your printer. Rory 708-597-4222
Before Windows boots, determine which keyboard command you need to type to enter the "setup" or BIOS. Hit that key and it should get you into the BIOS. Once in the BIOS, go to the boot priority settings and set the DVD to boot first. Normally the harddrive is first.
This error code is usally related to the printhead cartridge not running smoothly on the printhead shaft. Clean the shaft with a paper towel and some alcohol, let dry then take a clean paper towel with some WD-40 and apply to the printhead shaft. Move the printhead assembly from side to side. This should take care of all errors that are 50-59.
