Question about Rotel New Original RR927 Remote Control
Volume buttons on the RR-927 remote do not work
I can use the Rotel RR-927 to turn the RTC-940AX on and off. I can change stations using the 1-9 buttons. The AM-FM Band button works. The Tuning up/down works. But the volume up/down buttons do not work. I have to manually use the volume control knob on the RTC-940AX. Any ideas why the volume buttons do not work?
SOURCE:
  • 319 Answers
SOURCE: Rotel RMB-1095 Power Amplifier Problem
Sounds like wiring problems. Unhook everything, then get owners manual for proper instruction
Posted on Apr 17, 2008
SOURCE: Rotel RX-800
I have an RX 600 - which has just gone 'phut' - which is how I came today to find this website ! I once had your speaker problem but eventually tracked it down to a bad connection of the speaker cable into the rear of the Receiver. Plastic sheathing and dust was partly in the way. Strip off a bit more plastic to expose fresh bright wire, and remake secure tug-proof connection before you try anything else. Oh, and while you doing it, do the others as well !
Posted on Sep 11, 2008
fixyathing
  • 341 Answers
SOURCE: Rotel RA01 amp - volume control
Make sure you connected your record player in the right inputs. Better try it to a line level auxilliary input that is sure to pass the volume control. hope this helps..
Posted on Sep 25, 2008
  • 222 Answers
SOURCE: Hi i have a Rotel
Try fixing your remote controller, because sometimes when we neglected to replace our remote batteries for a while, it will leak and it will build up on the contacts of the remote pad.
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Good luck
Posted on Sep 28, 2010
dunnbiker
  • 8546 Answers
SOURCE: Rotel RTC-850 Preamp left channel
Before we throw in the towel, turn it off and exercise every control a lot of times throughout its range, particularly the Tape Selectors. Sometimes oxides will develop on seldom used controls and their 'normally closed' contacts will not pass a signal.
Posted on Dec 26, 2010
Testimonial: "Wow, it works after selecting each of the input buttons a few times. I could not be happier. Thank you so much."
Preseting radio stations so i don't have to use the tuning dial everytime
Most radios let you set them like this - select bandwidth FM/AM then tune to a favourite station, find the row of numbered buttons under digital display (usually 1 - 5) then press and hold button 1 for a few seconds, the station will be set to button 1, so to speak. Repeat tuning to another station then press button 2, etc...some radios have up to 15 slots per band. How many stations do you listen to....
To recall station 1, press button 1 ..button 2.......... Red.
Apr 05, 2014 | 1997 Isuzu Hombre
Tip
USING THE WEATHER BAND STATION 1. FOR WEATHER STATIONS, CLICK THE WEAIHER...
1. FOR WEATHER STATIONS, CLICK THE WEAIHER BAND/AM/FM (13) TO “WB”.
2. TUNE FOR THE WEATHER STATIONS BY THE TUNING (14).
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
How do I change the radio station on my pioneer vsx-d903s
Welcome to FixYa.
You need to use the remote control to access the radio station frequencies.
Follow the instructions below:
Thank you for using Fixya. Have a great day!
Jas247
Jul 23, 2011 | Audio Players & Recorders
I knave a teac model ex cd3. Have lost the manual. Can't remember how to reset the radio stations. Can you help?
OK press power on,select tuner button for radio. then select band AM or FM. Then press tuning mode button until you see [manual] in the window. then press the tuning button [arrow left or arrow right buttons] until you get to your desired station.then press program / memory set. a memory number will flash [ say memory 1]. then press program/ memory /set button again to lock in the selection [memory 1] now this is the TRICKY PART. Once the selection is memorized go back to tuning mode Press the tuning mode button until you see manual and i think you can follow the above procedure. If you program AM stations first Then press the BAND button to get FM stations and go back to step one.
Feb 17, 2011 | Teac EX-CD3 CD Shelf System
Brookstone SLCDv2.0 The device clearly has a Memory capability since there is a "Set" button and the display shows "Memory" when the button is pressed at a particular FM station. ...
Hi, The receiver does have an in built memory to store upto 6 channels.Please follow the steps below to set up the radio memory:- Up to six favorite radio stations (3 AM and 3 FM) may be stored in memory. the following are steps to set radio memory: 1. Press tUnInG/bAnD to select the band. 2. turn tUnInG/bAnD to locate the desired station. 3. Press the M button. the "M" indicator flashes on the LCD Display. 4. Press 1, 2 or 3 to store the selected station. 5. Press the M button again to confirm. 6. repeat steps 1-5 to set other memory stations.
Incase you would require any information do refer the below web site where you could find picture representation of the same. http://www.brookstone.com/linkedassetservlet?assetId=71937&languageId=EN
Thank you for your time and best wishes for your effort.
Jan 11, 2011 | Audio Players & Recorders
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
Dec 24, 2010 | Teac CD-X9 Shelf System
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
37
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
My Grundig Satellit 700 Radio is not working on FM Band but is working well on AM and Shortwave Band. After pressing ON/OFF button and FM/RDS-AF button when we try to operate the FM Band of this radio...
As a side note, most AM/FM radios use a separate antenna for each band, thus why you can pick up AM but not FM. Check your mast antenna connections to make sure they are solid and not missing or loose.
Dec 10, 2010 | Grundig Audio Players & Recorders
Clarion RAB250D w\casset need to set clock and stations.
While pressing the BAND button, press the DISP button for 2 seconds or MORE to enter the clock editing mode.
To move between the hour and nimute fields, use the left (hour) and right (minute) buttons.
To store the clock setting, press the BAND button.
Also to change between manual tuning and seek tuning press and hold the BAND button for 2 seconds of more. "SRCH" will appear in lower side of display when in search mode.
To preset a station manually press the BAND button to select the band at which to store the station (AM, FM1, FM2, FM3).
Tune to the desired station to be preset
Press and hold the corresponding preset button (1-6) for at least 2 seconds to store the station into memory.
Apr 26, 2009 | Clarion RAB250D
AM reception is not working
Turn the power off and then press the UP tuning button several times, hold in the tuning up button and then turn power on and release both buttons. It should would work perfectly.
Aug 16, 2006 | Sangean DT110 AM/FM Radio
Rotel New Original RR927 Remote Control Logo
Top Rotel Televison & Video Experts
Raj Patel
deton8 von Splosion
Tom Chichester
Are you a Rotel Televison and Video Expert? Answer questions, earn points and help others
