Bosch WET 2820 Front Load Washer / Dryer Logo
m
martin west Posted on Dec 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Broken belt motor works but drum doesnt turn
Steven Brandon
Level 3:
Master:
  • Bosch Master 462 Answers
  • Posted on Dec 11, 2013
Steven Brandon
Bosch Master
Level 3:
Master:
Answers
462
Questions
0
Helped
117861
Points
1705
Buy new belt for washer, pop off back plate, put new belt on.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
1helpful
2answers
How to fix dryer
Maybe a broken belt. Maybe a bad door switch. Maybe a bad motor. Maybe improper voltage. Maybe thermal fuse.
My bosch nexxt500 wont rotate the drum, the water pump work but the motor doesnt rotate the drum
Check if the lid isnt working as this prevents a roration . Else must be a loosened or broken belt that rotates the drum as the motor works . Hope this helps
2answers
Dryer powers up but the drum doesnt turn
The drive belt is either broken or the belt tensioner spring is broken.
My machine wont stay on wash cycle.it starts turns a few times then turns itself to the "on" mode
If the drum is turning then its most likely the tacho on the back of the motor or the wires connecting the tacho to the control panel. So the motor is turning but the panel can't control the speed so will switch off straight away.
If the drum doesnt turn but you hear the motor kick, then the drum belt is broken...
1helpful
The dryer heats, motor runs but drum doesnt turn.
Could be one of several things. The drum turns by motor and fan belt around the drum. The most common problem is that the fan belt is broken. Check to see that the drum is free and not bound up by frozen bearings. Also that nothing is jamming the drum. If everything seems to be ok --- you need to check the pulley on the motor shaft and be sure it is tight on the shaft . More than likely -- it is a broken belt. I hope this helped.
Heating works but drum doesnt turn.
Try turning drum, or remove top from dryer to confirm if belt has gone. When turning drum there should be some resistance as the belt fits around the drum
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 • Dryers
Motor runs but drum doesnt spin
The belt may have broken, you must open the dryer case and check the belt. If broken, you'll see it laying on the bottom
The dryer will not start - the sensing lite comes on, and thats it. the motor doesnt even attempt to turn. the door open lite (in the drum) works with the door switch
sounds like the drum belt is broken there is a cut off switch to prevent the dryer from running/overheating if the belt may break
Drum doesnt turn... motor fine.
From your description I would suspect a broken belt although I am unfamiliar with your model. Once the belt [which transfers drive from the motor to the drum] breaks, it would'nt matter how well the motor runs, it can't turn the drum.
Hope this helps!
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
