As oppesed to the control itself i believe the touchpad is the colprut it plugs into the control and its a lot less expensive. The model number listed on your question,please replay with full exact model off the label which on that wall oven is either on a label by the door hinges or on the bottom or the control console between it the console and top edge of door. reply with that and i will give you the part number for that touchpad.
F2- oven too hot. usually due to a bad oven temperature sensor. they sense the temperature of the oven by changing resistance, and can keep the element hot, or turn it off.
you have a bad bake ignitor.i don't know what number you sent but it's not the model number,open the draw below the oven door and look at the frame where the door closes into and you'll see a tag with the model and serial number,call your parts store,give them the model number and tell them you need a bake ignitor
mlong9876 - I am having the same problem as you posted re: Maytag (mgs5870adw). I am trying to arrive at the same resolution changing the lower igniter in my same model oven. Were you able to remove the lower oven plate to access the top of the burner and igniter with the convection bake fan housing in the back? I am having difficulty getting to the igniter.
You do not give much information, such as the model number, or if it is even gas or electric. If it is electric, the oven element is the most likely cause. If it is gas, the oven glow bar ignitor is the most likely problem. (Oh, by the way, that's broiler, not boiler)
Hi you can order the thermostat and it is easy to replace, you will need the make , model and s/n to get the cocorrect part if you need to to fine the oven control just get back to me ,
