Electronics - Others Logo
A
Anonymous Posted on Dec 10, 2013
Starting em 7000 is
Starts but shuts off
1 Related Answer
Anonymous
  • 7 Answers
  • Posted on Sep 10, 2009
SOURCE: I have a Honda 7000 EM inverter generator. When it
ARE SURE ITS THE OVERLOAD LIGHT AND NOT THE NOIL ALERT? IF ITS THE OIL ALERT ITS CAUSE YOUR LOW ON OIL OR THE SENSOR INSIDE THE GENERATER IS BAD?
Tahoe 7000 lxr diesel generator starts and runs then 2 min. later it reves up and down then shuts off
indicates insufficient fuel flow through the tap or filter in the tank
all engines will increase in rpm as the mixture leans out from insufficient fuel in the carby then will shut down from lack of fuel
Onan marquis 7000 generator, cranks up runs for about a minute then starts loping, starts to shut off, choke opens, any ideas
Clean the carb and all the orifices inside the carb under the bowl. It will probably run after that.
How is the carbeurator bowl on an ONAN Marquis 7000 genset removed? I think it sat too long without Stabil and became clogged. It appears to be, maybe< pressed on as there are no visible holdong
They are generally sealed, as it affects the mixture. You can take the carb off, put on the bench and remove the shut off solenoid at the bottom of the bowl, remove black cap on main jet, remove screw, and unscrew the bowl. To set back up you will need to ideally check on a load bank, for ability to pick up full step load,
I have a Onan 7000 genset in my rv It starts and
Either you have a kill wire ( if I remember it is the brown wire) that is disconnected on one end or the other Or your in coach switch is bad.
Check the switch this way
Remove the switch from the dash/ mounting surface unplug the brown wire - start the genset - ground the brown wire - it should kill the motor
If it kills the motor your switch is bad
My Minolta 7000 makes funny sounds
Probly not. I suspect old, dried up lubricant gumming things up. causes resistance, motors stress out and it shuts off.
You can send it in for repair and Clean/ Lube/ Adjust. or get another on Ebay. Any Minolta Maxxum will use the same lenses.
lightspiritphotography.com
I have a Honda 7000 EM inverter generator. When it starts after a few seconds the overload light comes on and it shuts down. What is the problem?
Dryer will run when you turn the start switch, after releasing the knob dryer shut off, just replaced the heating elements, could I have a wire crossed. While holding the start switch on I can open the...
There is so much dryers can tell you, so much they can say. The problem is the start switch, the contact terminals are obviously not touching when the switch is relaxed. Try replacing the switch alone. This should get 'em. :)
May 05, 2009 • Dryers
Minolta Maxxum 5000
I had the same problem with a maxxum 7000. Traced it to a bit of corrosion in the battery pack. It let just enough power through to run the computer, but upon releasing the shutter, it shut off.
You might check that. corrosion can be cleaned with vinegar.
-John
Top Honda Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
goneforever.
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
