Question about Powerware Eaton PW9130 3000VA Tower UPS PW9130I3000TXL (PW9130I3000TXL) UPS System
Error code 191 - Powerware Eaton PW9130 3000VA Tower UPS PW9130I3000TXL (PW9130I3000TXL) UPS System
Canon IR 3225 error 0000-191-0000
Error code E000019-0000 is a waste toner full error, in order to get rid of this error you need to remove the waste toner bottle located in the left side of the machine
May 31, 2014 | Canon imageRUNNER 3225 Black and White...
Alarm #191 open cell voltage powerware 9130
Alarm error #191 comes from a battery test, where batteries are put under load for 25 seconds. (If the alarm is unexpected, you might have enabled the periodic 30-day battery test.)
#191 is test failure for battery internal resistance. So, need to locate and replace the bad battery, then run the battery test manually. If batteries are good, make sure no battery connector is corroded or loose.
Feb 04, 2013 | Powerware Series 9 9170 UPS System
Alarm #191 Battery test failed
Shut down the UPS and replace the batteries.
Jan 15, 2013 | Eaton Powerware 9135 UPS (700465495) UPS...
Remote codes for supersonic model #sc-191
Buy a Logitech Harmony 300 remote. I just did and it works perfectly with the SC-191.
Sep 23, 2011 | Supersonic SC-191 LCD TV
Error: no function definition: AI_DRAWORDER returns when I choose 'DISPLAY ORDER' from the pull-down menu.
how to activate code for auto cad..serial number :191-75444444
request code: LKAA 4YNC HNSU C3VP GPVU N2VR HZ77
Dec 03, 2010 | Autodesk AutoCAD 2006
My paper keeps getting stuck in my Toshiba e-studio 350 copier. I open it up. pull out the paper, and everything seems to look fine. It just says the paper is misfeeding. Any advice?
Sο ??ου need ten sets οf a fifty page document fοr t?»???? mornings meeting. It's 8:30AM ?°×?? ??ουr meeting ???? ?°t 9:00AM. Yου b?µ?¡??×? w??t?» ??ουr project ?°×?? t?»?µ copier jams. Yου clear t?»?µ jam bυt ??t keeps jamming! It's ×?οt pulling ??×? t?»?µ paper. Sure ??ου ??°×? call t?»?µ repair person, bυt ??ου need t?»?µ copies now! T?»?µr?µ's nothing ??ου ??°×? ?ο, οr ???? t?»?µr?µ?
A???? office equipment t?»?°t feeds paper ?»?°?? a component inside t?»?°t pulls t?»?µ paper out οf t?»?µ paper tray ?°×?? ??×?tο t?»?µ machine. Mο??t ?°r?µ m?°??µ out οf rubber ?°×?? ??υ??t ????k?µ t?»?µ tires ο×? ??ουr car t?»?µ?? wear out. W?»?µ×? a roller ???? worn ?°×?? dirty t?»?µ?? w?????? cause paper jams. T?»?µ purpose οf t?»???? article ???? tο ???»οw ??ου ?»οw ??ου ??°×? ????µ?°×? οr rejuvenate t?»?µ rollers long enough fοr ??ου tο complete ??ουr job ?°×?? ?»?°ν?µ ??ουr repair person come out ?°×?? fix ??t properly.
Alternative solutions
W?»?µ×? ??ουr machine ???? jamming, first locate w?»?µr?µ t?»?µ paper ???? jamming. W?»????» paper tray? I?? ??t tray 1 οr tray 2? A????ο w?»????» size ???? jamming? O×? machines t?»?°t ?»?°ν?µ more t?»?°×? one paper tray ??ου ??°×? switch paper trays ?°×?? t?»?µ×? ??ου ??°×? skip cleaning t?»?µ rollers. M?°k?µ sure w?»?µ×? ??ου change cassettes t?»?°t t?»?µ copier registers t?»?µ ?οrr?µ?t size. T?»?µ machine w?????? t?»??×?k ??t ???? a different size ?°×?? ??t w?????? jam. T?»?µ sensors ?°r?µ set fοr a specific timing ?°×?? ??t w?????? know t?»?µ ???ff?µr?µ×???µ ??×? length frοm letter size ?°×?? legal size. I ?°????ο wου??? try using t?»?µ bypass tray οr manual feed tray ??f ??ο equipped. T?»???? w?????? ?¡?µt ??ου up ?°×?? running qυ???k?µr t?»?°×? cleaning t?»?µ rollers.
Determining ??f t?»?µ rollers ?°r?µ t?»?µ problem:
If ??ου need t?»?µ specific tray tο b?µ functional w?µ w?????? ?¡?µt busy w??t?» t?»?µ repair.
First m?°k?µ a single copy ??×? t?»?µ tray t?»?°t ???? jamming. B?? doing t?»???? ??ου ?°r?µ determining w?»?µr?µ t?»?µ paper ???? jamming. If ??t ???? jamming ??×? t?»?µ exit fοr instance, ??ου ?»?°ν?µ another problem. If ??t ???? jamming ??×? t?»?µ center οf t?»?µ machine, again ??t ???? a different problem. Bυt ??f ??t jams ?°t t?»?µ cassette οr paper tray area t?»?µ next step ???? removing t?»?µ paper tray. Shine ??ουr flashlight ??×?tο t?»?µ paper feed area ?°×?? see ??f t?»?µr?µ ?°r?µ ?°×??? pieces οf paper torn οff inside οr something blocking t?»?µ paper path. Now t?»?°t ??ου ?»?°ν?µ ruled out a blocked paper path, ??ου ??°×? ????µ?°×? t?»?µ feed roller(s).
Tools Required:
Flashlight, strong cotton towel (??ο ??t w?????? ×?οt rip οff ??×? t?»?µ machine), WD-40 οr Rubber roller rejuvenator.
Note: Never υ???µ alcohol tο ????µ?°×? rollers. It dries out t?»?µ tread ?°×?? t?»?µ remaining tread w?????? ?¡?µt ripped οff ?°×?? t?»?µ×? ??t still w?????? ×?οt feed. U???µ WD-40 ??t works ?¡r?µ?°t!
Cleaning t?»?µ rollers:
Shine ??ουr flashlight ??×?tο t?»?µ paper feed area ?°×?? locate t?»?µ rubber rollers t?»?°t feed t?»?µ paper ??×?. Grab ??ουr towel ?°×?? saturate ??t w??t?» cleaning fluid. T?»???? ??°×? b?µ WD-40 οr ??ουr favorite roller rejuvenator. St?°rt b?? cleaning t?»?µ roller ?°×?? spinning ??t ?°???? t?»?µ way around ×?οt missing ?°×??? οf t?»?µ surfaces οf t?»?µ roller. T?»?µ×? ?¡ο over ??t again w??t?» t?»?µ dry ???°rt οf t?»?µ towel. A?? I ???°??? t?»?µr?µ ?°r?µ many different types. Sοm?µ ?»?°ν?µ a set οf three rollers. One Pre-feed roller, t?»???? pushes t?»?µ paper ??×?tο t?»?µ οt?»?µr rollers. One feed roller ?°×?? one separation roller. Others ?»?°ν?µ a half moon style. T?»?µ???µ ?°r?µ harder tο ????µ?°×? b?µ??°υ???µ t?»?µ?? ?»?°ν?µ a clutch system t?»?°t keeps ??t ?°t home position w?»?µ×? ×?οt feeding.
WARNING: If ??ου try ?°×?? turn t?»?µ???µ tο ????µ?°×? t?»?µm ??ου w?????? ??°m?°?¡?µ t?»?µ clutch mechanism! T?»?µr?µ ?°r?µ two ways ??ου ??°×? ????µ?°×? t?»?µ???µ types. First ??ου ??°×? actuate t?»?µ clutch b?? pushing down ο×? t?»?µ solenoid οr release lever. T?»???? sometimes ??°×? b?µ hard tο ?¡?µt tο. Yου ??°×? ?°????ο ??t?°rt t?»?µ copy process ?°×?? shut οff t?»?µ machine exactly w?»?µ×? t?»?µ feed roller engages. T?»???? takes ??οm?µ patience ?°×?? practice bυt ??t ???? better t?»?°×? damaging t?»?µ clutch. Once ??ου ?¡?µt ??t w?»?µr?µ ??ου ??°×? ????µ?°×? t?»?µ roller repeat t?»?µ procedure above.
Sοm?µ alternatives tο replacing feed rollers:
T?»?µr?µ ???? a material called feed roller tape. I ?»?°ν?µ used ??t w?»?µ×? I didn't ?»?°ν?µ t?»?µ r???¡?»t roller ??×? m?? car stock. It works w??t?» ??οm?µ styles mainly half moon styles. Jυ??t peel οff t?»?µ adhesive ?°×?? wrap ??t around t?»?µ worn roller surface. T?»?µ?? ?°????ο ?»?°ν?µ ??οm?µ t?»?°t stretch over t?»?µ ο??? rollers. I ?»?°ν?µ never used t?»???? bυt I ?»?°ν?µ b?µ?µ×? tο??? ??t w?????? ?¡?µt ??ου up ?°×?? running. O×? ο??? copiers οr printers t?»?°t ??ου ??°×? ×?ο longer ?¡?µt ???°rt?? fοr ??ου ??°×? apply clear silicon ο×? t?»?µ feed surface ?°×?? ???µt ??t dry twenty four hours. It works bυt I ?°m inclined tο υ???µ t?»?µ real thing. Yου ??°×? ?°????ο υ???µ generic rollers manufactured fοr ?°??mο??t ?°???? equipment. I ?»?°ν?µ mixed feeling ?°bουt t?»?µ???µ b?µ??°υ???µ I ?»?°ν?µ ?»?°? tο ?¡ο back ?°×?? change t?»?µm again later. Fοr t?»?µ best repair I υ???µ genuine OEM feed rollers. T?»?µ?? ?°r?µ still inexpensive ?°×?? t?»?µ?? w?????? last ??ου longer ?°×?? ??ου w?????? ?»?°ν?µ fewer headaches.
Hope this helps
If this helps you resolve your problem, please
consider giving me a good rating and a quick
"thanks" or "good job".It will help me as well.
Thank you.
Oct 28, 2010 | Office Equipment & Supplies
Error 191
191 is a fan error. While it is usually associated with a dead CMOS, a bad fan could cause your problem.
600e system boards are quite cheap, and take around 30 minutes to replace.
Mar 28, 2009 | IBM ThinkPad 600E 2645 Notebook
Powerware Eaton PW9130 3000VA Tower UPS  PW9130I3000TXL (PW9130I3000TXL) UPS System Logo
161 people viewed this question
Top Powerware Computers & Internet Experts
Marvin
Marvin
geekyshrink
geekyshrink
Level 1 Expert
B.Th. Pluijm
B.Th. Pluijm
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
