What is a good replacement to the 30 inch Kenmore Elite Induction Cooktop Model 42800? I do not want to enlarge the existing opening in granite.
SOURCE: 30" wolf induction cooktop and it is locked in showroom mode
Hiya, hold the child lock button for 3 seconds. should unlock. Best of luck
SOURCE: Installing cooktop into granite countertop
Put a bead of clear sylicone caulking around the cutout , then set the cooktop in place .
SOURCE: Kenmore Elite Induction Cooktop Error Code 41
I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
Anyone else experienced this failure??
SOURCE: whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Hello friend, thanks for your post!
I see you are searching for instructions on how to change the filter board on your Electrolux cooktop. Some of these intricate part replacements do require precision and patience, therefore when replacing electrical components or removing them from your appliance, I would suggest seeking professional assistance. One must be very careful as there certain replacement parts could result in potential harm. Best regards. -Matt
