We need to now that what will be the pressure in operation of the unit suction and discharge pressure please help us.
SOURCE: i have a ice maker that keep freezing up. the
For a 404 system pressures should be about 60/350 Remember when you recharged always with the freon drum upsidedown so liquid gas is going in to the system.But if it's freezing up could be the thermostat or the timer or the heaters.
SOURCE: t-23f not freezing
Depends on how technical you want to get. Generally, measure the ambient temp of air entering the condenser coil. Add 30 degrees to that temp and convert to psi using a P/T chart. This will get you to a starting point.Remember, charging a "Hot" box takes time. Don't over charge.
SOURCE: i would like the normal
http://www.totaline.com.ar/site/uploads/file_7-200652412174-0.pdf
Here is a PTC with all of the refs.
