Lands Phones Logo
Posted on May 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking to join two Nortel MICS pbxs using E&M 8 wire cards and cisco Vic2-2e/m cards with the two cisco boxes both plugged into the public internet and faking an E&M channel so the nortel switches think they are wired together even though they are miles apart - any suggestions on configuration of routing for the nortel or configuration of the cisco 2801 router with the vic2-2e/m card in it?
Anonymous
Level 2:
  • Expert 192 Answers
  • Posted on May 12, 2009
Anonymous
Expert
Level 2:
Answers
192
Questions
Helped
239312
Points
557
There is another web forum that specializes in this type of task, they are a group of techs... the forum is called Tek-tips(dot)com...
This is for techs that have major issues and need connections to other techs in the field.
Under the Search: look for Nortel and Norstar systems.
3answers
What collaboration capabilities are available on the new Cisco 2900 and 3900 Series routers?
According to my experience and knoledge: the Cisco 2900 and 3900 series platforms have collaboration feature parity with the Cisco 2800 and 3800 Series platforms, so all of the following collaboration capabilities and solutions are present:
• Cisco Unified Survivable Remote Site Telephony (SRST)
• Cisco Unified Border Element
• Time-division multiplexing public-switched-telephone-network (TDM PSTN) and private-branch-exchange (PBX) gateways
• VoiceXML contact-center gateways
• Cisco Unified Communications Manager (UCM) media resources (allowing conferencing, transcoding, and Media Termination Point [MTP])
• Resource Reservation Protocol (RSVP) Agent
• Cisco Unified Communications Manager Express (CME)
• Cisco Unified SIP Proxy
• Gatekeeper
Cisco 3900 Series Routers
How do I reset my phone system? Nortel Norstar
It's simple.
On Vmail it's Ftr 983 -> pswd -> 1 -> reinstall -> yes
On MICS it's pull the power plug off and within 15 minutes -> Ftr** -> startup -> pswd
To be sure follow the users manual instructions. You can get the pdf user manual here: Nortel Norstar pdf manual
Power source
A Nortel Key Service Unit, an ICS (MICS,CICS), BCM (50,100 etc), Norstar (308,616,824), an Avaya IP Office running Nortel cards, or there is another company that makes a Nortel emulation key system but I can't recall what it is right now.
Carl
How to configure NORTEL T7208 with cisco CME
No, the nortel phones you have are digital. Cisco is an IP system (not very good either)
How to program nortel T7208 to have feature > 981 with an "other" option
After entering the mailbox access F981, press "#", the display should change from Pswd: to Log:. Now, enter the alternate mailbox number followed by the password for that box and "#". The remainder of the prompts should be the same as accessing the 'native' mailbox.
Blue tooth wireless mic stops recording after 8 minutes
don't know what program you are using to make the recording(s) with, but have you checked to make sure that the program is set to record more than 7-8 mins of speech? (some programs, like youtube, etc only allow about 10 mins recording for certain formats)
or that there may not be enough memory allocated for the program / file format being used?
My tascam dr 100 gives a 'writing failed' file error' message and stops recording
Try using a smaller memory card. This only happens to me when using a 4- or 8-gig card. 2-gig and below, No error.
Getting the M7208 to work
Nortel M7000 series are proprietary sets which require a nortel MICS, CICS, or an older 8x24, 6x16, or 3x08 in order to work. If you have the system, it maybe that the jack isn't activated with a system port.
2answers
Cannot get nortel callpilot 100 to communicate with nortel CICS
This is the forums for Avaya, I would repost in the Nortel side. BUT, i do know the CICS needs to be of the correct revision to work with CP.
Nortel Extranet VPN using ESP IPSec
Step 1 Go into the web-based configuration on the router (enter 192.168.0.1 in your web brower). Enter username (admin) and password (blank). Step 2 Click on Advanced at the top and then click on Applications on the left side. Step 3 Check Enable Step 4 Enter a name (i.e. Nortel). Step 5 Enter 500 for Trigger Port (500 - 500). Step 6 Select Both for Trigger Type. Step 7 Enter 500 for Public Port. Step 8 Select Both for Public Type. Step 9 Click Apply and then click on Continue when prompted.
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
