Re: Do you havew to delete existing phone numbers in...
Yes I did solve my problem. Just lift the receiver, Push program key, enter full number and push program key again, then push the button above the space you want to store the new number in and hang up the phone. Did not have to delete the old number. Thanks.
Lift the head set. Press PROG button twice. Then press MEMORY then the speed dial number. Hang up. Done. Or..Lift the head set, press PROG, enter a phone number you'd like to set to speed dial, press PROG, MEMORY, the speed dial number (1,2,3,4 etc), then hang up..
To assign or change youe speed dial. Do the following:
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.)
NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B,
or C to select a location.
3. Press STORE again to confirm the memory location.
NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then
press STORE to save.
5. Use the number keys to enter the name of the person associated with the
telephone number you just entered. More than one letter is stored in each of the
number keys. Press the keys multiple times to scroll through the letters for that
key. For example, to enter "B," press "2" twice. Press LEFT two times to create a
space.
NOTE: The flashing cursor automatically moves to the next position
If you are asking about Outside Auto Dial numbers (a "speed dial" number programmed to a button), follow these steps:
1. Leave the handset down
2. Dial "Feature (star) 1"
3. Press the button to be programmed
4. Enter the "speed dial" number
5. Press button under "OK" on the horizontal display.
The group of 12 buttons on top of an M7310 phone are Dual-Memory buttons, each can hold 2 speed dial numbers. When you press the button, you are using the Lower Memory location. When you press the Shift button (triangle-shaped button on the right) and the a Dual-Memory button, you are using the Upper Memory location. Good Luck!
Hi, I found a way to get Speed Dial on the Eternity or Ultra Touch . As follows: 1. Copy all address book entries from Sim to Phone Memory. 2. Delete all Sim Address book entries. 3. Switch Address book source to Sim. 3. Re-enter up to 99 speed dial entries in Sim, in the exact order you want them to be assigned to speed dial. 4. Switch Address book source back to Phone Memory.
From now on all numbers on the Sim will be in Speed Dial and you will view the address book from phone memory. Of course any number can be in both places.
Now to speed dial just enter 1#, 2# etc for any number in the Sim Address book. You will get to view and confirm the entry and then dial. In a way this is even better then the speed dial functions on older Samsungs, as the preview before dialing ensures you have the right speed dial entry.
I think it works fine. dk
check your phone memory limit may be it is full.
if it is still empty u need to reset all settingms of your cell phone to factory defaults.
Go to setttings then reset your celll phone.
but i think your cellular limit is over for save new contact check it .
Here are the commands to run the phones memory dial (speed-dial). I have included the instructions for deleting and changing numbers as well. It is listed below. I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS
Store up to ten 20-digit numbers in memory for quick dialing.
Storing a Number in Memory
1. Make sure the phone is OFF (not in TALK mode).
2. Press the MEMORY button.
3. Press a number (0-9) to store the dialed number in that memory location.
4. Press the MEMORY button again.
5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm.
6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number
1. Repeat steps 1 through 4 in Storing a Number in Memory.
2. Press the REDIAL button.
3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number
1. Repeat steps 1 through 6 in Storing a Number in Memory.
2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number
1. Make sure the phone is ON by pressing the TALK button.
3. Press the number (0-9) for the desired memory location. The number dials automatically.
Inserting a Pause in the Dialing Sequence
Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers
1. Press the MEMORY button.
2. Press the desired memory location (0-9).
3. Press the MEMORY button twice to delete the entry.
4. You will hear a confirmation tone.
I believe what you want is at the bottom of this list.
If you frequently send faxes to the same group of telephone numbers, you can assign these numbers to a group.
Only Speed Dial and One Touch numbers can be assigned to a group. A maximum of 25 Group Numbers (WorkCentre Pro555) / 50 Group Numbers (WorkCentre Pro575) can be assigned (in the range 1-1999). Preset group numbers can also be used for polling. The following information is included below:
Create a new group
Add numbers to an existing group
Delete numbers from an existing group
Delete an existing group
To print the Group Phonebook, see the Related Items below for additional information. Create a new Group:
From the Standby Mode, press the [Menu] (up arrow) button on the Control Panel, then press [3], [3].
Use the numeric keypad to enter the Group Dial number (1-1999) you want to assign to this group.
Press the [Enter] button. The screen will display a name.
Use the numeric keypad to enter the Group Name (20 characters maximum), then press [Enter].
Press the One Touch button you want to include in this Group, or enter the Speed Dial number, then press [Enter].
NOTE: The One Touch and Speed Dial numbers must already be programmed. See the Related Items below.
Repeat step 5 to enter additional numbers.
When you have entered each number you want to include in this group, press [Enter].
NOTE: Group Transmissions are easier if a group is linked to a One Touch button.
To assign this group to a One Touch button, press the One Touch button. To skip this step, press [Enter].
Press the [Exit] or [Stop] button to return to the Standby Mode.
To add numbers to an existing Group:
Press [2] to modify this group.
Use the numeric keypad to enter a new group name, then press [Enter], or press [Enter] to retain the old name.
Press the One Touch button you want to include in this Group, or enter the Speed Dial number, and then press [Enter].
Repeat step 6 to enter additional numbers.
To delete numbers from an existing Group:
Press the One Touch button you want to delete from this Group, or enter the Speed Dial number, and then press [Enter].
Press [1] to delete this number.
Press [Enter] to delete the number, or press the [Exit] or [Stop] button to exit without deleting number.
Repeat steps 5 through 7 to delete additional numbers.
When you have deleted each number from this group, press [Enter].
Press [Enter].
To delete an existing Group:
Use the numeric keypad to enter the number of the Group you want to delete, then press the [Enter] button.
Press [1] to delete the group number.
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed. Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
