Washing Machines Logo
A
Anonymous Posted on Dec 09, 2013
Can i reverse door on Frigidaire ATF6000ES1 washer
Can i reverse door opening side
5 Related Answers
Mike Pham
  • 54 Answers
  • Posted on Jan 21, 2009
SOURCE: Door opens on wrong side
I don't think you can on a front loader washer.. on your dryer you can see how they have screw covers for interchanging, but on washer there are none.. sorry.. good luck..
Anonymous
  • Posted on Jan 02, 2010
SOURCE: Frigidaire washing macine ATF6000ES1 error code E47
Hi I have the same problem, Error Code 47. I went to the support page and only found manuals and the tech data sheet. Which one shows you how to get to the front door lock? Thank you
Anonymous
  • 1197 Answers
  • Posted on Aug 30, 2010
SOURCE: frigidaire Affinity ATF6000Es1 washer- Keep
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Anonymous
  • 1010 Answers
  • Posted on Mar 24, 2013
SOURCE: frigidaire front load washer front door
Check the door latch
prem mathew
  • 662 Answers
  • Posted on Apr 06, 2013
SOURCE: Frigidaire Affinity Front-loading washer wont do anything
Check the wall socket with another electric gadget. Check your washer plug fuse. Finally open up the rear (after taking the washer power cord off the wall of course!) and disconnect and reconnect all wires and connectors one by one. Possible it could just be a loose connection somewhere. Sometimes happens due to vibration.
Click so pl if helped.
Can I reverse the door swing on a Frigidaire LTF2140ES0 washer
Thank you for your inquiry, Sterling Calhoun!
From the information you have provided you would like to reverse the door swing on your Frigidaire washer. I have reviewed the manuals for your washer and I was unable to locate any directions on reversing the door. If you need any further assistance please feel free to reconnect. -Matt
Frigidaire washer model ATF6000ES1 door not locking, the door closes, but it's not recognized by control panel.
You are having a problem with the door latch sensor indicating everything is connected correctly. Check to make sure your door is not sagging and then make sure the door latch is not broken or cracked.
Fix door ATF6000ES1
What is the problem with the door?
Need to turn doors around , doors are opening to left side..need to open to right side
Good day,
Start from the top and work down.
Make sure all items are removed from both doors, and machine should be shut off.
1. Remove top bracket with the freezer door still shut.
With both hands, open freezer door about 1 foot, and lift off.
All thru this process keep track of all shims and washers and their location.
2. Remove center bracket holding main door and remove using the same process as with the freezer door.
3. Remove bracket from the bottom and reverse to the other side.
There will be a lot of press in buttons to be removed by prying them out with a small screw driver.
4. Reinstall in reverse order, making sure all shims and washers go back where they came from. As well, Tighten screws while making sure the door is in alignment at the same time.
5. Remove both door handles and reinstall. Some screws may be hidden by a cover that will have to be pried away first.
3helpful
Frigidaire Affinity ATF6000Es1 washer- Keep getting an alarm and an E10 code and have to restart the washer each time the code comes up.
6helpful
2answers
Frigidaire affinity atf6000es1 - control panel locked
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines hope it may for you..............And please rate me if helped
1helpful
3answers
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
