Both heating elements in oven of Kenmore 790.96112403 Electric Range stopped working suddenly. The range top, clock and time all work fine. When I try to turn the oven on, I hear a "click" like a ususally do when the oven is turning on - but no heat from either element. Could it be a blown fuse in the oven? I have already tried unplugging it and also checked by house breaker box.
If you have a multimeter, this is fairly easy. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/11-6-896507-/Kenmore-Oven-won-t-heat-79096112403
Testimonial: "Thank you so much! I have ruled out the bake and broil elements failing and checked the voltage out of the wall. So I am going to give the replacement of the oven control board replacement a try. Part is on the way - I will update after I replace the board."
Your welcome. That should solve your problem
Boo-ya! I replaced the board and the oven is working! Not bad for a mom with an accounting degree! Thanks so much - i will definitly reference your site in the future. Now back to baking cookies...
Your welcome Sandy. Happy that you could diy. Good job.
SOURCE: Kenmore Coil Top Range - oven portion stopped working abruptly.
If you are getting no codes and If the broiler works OK. Replace the bake element.
SOURCE: Kenmore Elite 790-99513307 side by side electric
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: Kenmore Electric Range - Surface heats up fine,
It appears your ERC/CLOCK has failed in this instance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: The oven heating element won't turn off
I would thing if you called an appliance service store or retailer and gave them the make and model number of the stove they can sell you one and maybe install it if you need them to but I would thing it would be called the oven switch
SOURCE: oven has power but none of the burners on top or the bake or broil elements work
Go to breaker panel,turn off and wait a minute and turn on,may reset it.
