Heating & Cooling Logo
Cary Diesterhaft Posted on Dec 09, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Protemp heater is not running right and blowing black smoke before it kicks on
Brian Mills
Level 3:
Master:
  • Master 613 Answers
  • Posted on Dec 17, 2013
Brian Mills
Master
Level 3:
Master:
Answers
613
Questions
0
Helped
133256
Points
1126
Sounds like you need a new nozzle and filter. Clean the pump strainer too.
Troybilt pressure washer starts when pump finally kicks in it loads up, dies and blows smoke
The smoke, is it blue or a very black smoke. Blue means oil leak past your rings, black means too much fuel, carb cleaning and or adjustment. Look at the plug, check for carbon build up there.
Jul 24, 2017 • Garden
Pentair minimax nt propane heater is blowing black smoke
is heater installed in a shed? how many btu's is your heater. You need 1 square inch per 1000 btu's for combustion air opening. Lack of combustion air will cause heater to under fire and produce carbon dioxide
7helpful
Protemp Sun-Stream 60,000 btu heater won't light
my protemp sun-stream 60,000 btu wont ignite fan runs but igniter just makes niose
Heater runs for approx.2 minutes then starts to blow black smoke
Here is a tip that I wrote that tells you how to troubleshoot a Torpedo orReddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
heatman101
Dayton Salamander Heater - Blowing Unburnt Fuel/Smoke Randomly
I have seen this before, you need to replace the nozzle.
THE HEATER STARTS THEB BLOWS ALOT OF SMOKE
There are any number possibilities for intermittent running.
1. Bad ground connection at the Ignition Device (transformer, spark box)
2. restricted fuel filter causing fuel starvation
3. crack in the plastic end cover
4. crack in the airline
5. crack in the fuel line
6. crack in the nozzle adapter
7. water in the fuel
8. Others I’m sure I left out
You must be the one to troubleshoot & find the cause.
Follow these troubleshooting tips
Ready hater 110,000 btu
replace the nozzle and check the fuel filter - if this is a kerosene heater. under the access plate is a round filter - remove it completely or change it.
Top Milwaukee Tool Heating & Cooling Experts
Paul Carew
john h
Are you a Milwaukee Tool Heating and Cooling Expert? Answer questions, earn points and help others
