Question about Lexar Media Jumpdrive S73 - Usb Flash Drive - 16 Gb
Lexar 16GB S73 appears as Innostor NAND Flash USB Device
Despite being used before, the flash drive had to have it's driver installed last time I plugged it in which resulted in it appearing as Innostor NAND. I can no longer access the files on it and have had no luck with changing the drivers back to Lexar due to the S73 driver not being present on the Lexar site or anywhere else I have looked. Any ideas? Thanks in advance!
  • Chester
    Chester Dec 09, 2013
    Also, the files which are on the flash drive are not terribly important at all but I would like to try getting the flash drive working again as opposed to buying another one.
    New Friend:
  • 43 Answers
Can you please confirm whether you can see the drive under 'My computer' or not? If you do and you said the files aren't that important, you can choose to reformat it through right click -> properties
Posted on Dec 11, 2013
SOURCE:
  • 86 Answers
SOURCE: lexar flash drive
First, download and try to extract all the files from your drive with this tool:
http://www.lexar.com/drivers/files/ImageRescue_2.0-u(b16).zip
Second, at the moment that you are sure that you have all your files backed up, if windows recognizes the drive, try to right click on it and format
Posted on May 06, 2008
  • 86 Answers
SOURCE: Lexar 2GB can't retreive jpeg's
download and Try this free utility- http://www.bestfreewaredownload.com/freeware/k-usb-t-free-undeletemyfiles-freeware-cnsyjket.html
gotgeek2
  • 565 Answers
SOURCE: How can i recover my files from my usb flash drive?
It's possible that you are still suffering from the effects of the virus. You can try to download a (free) program called "Restoration" and run it. Here's the link:
http://www.download.com/Restoration/3000-2094_4-10322950.html
If you manage to recover your files, I would recommend that you re-format the flashdrive to make sure that you are getting rid of the virus, then re-install your flashdrive software if you use it.
Posted on Jan 28, 2009
  • 24 Answers
SOURCE: How to recover data from a seemingly dead/non-functional USB flash drive
It sounds like your media is malfunctioning (electronics).
For this type of problem, we offer a data recovery service.
You simply have to send your media to us.
Our technicians will recover your files on CDs and return everything
within 48h. You just need to send us your Lexar with this form:
http://www.lc-tech.com/documents/LC_Technology_Data_Recovery_Service-SD-Eric.pdf
There is a charge for this service, but ONLY if we
are successful. The pricing is on the form. Please note
that the chances of recovery are around 90%.
Eric Beaudoin
ericb@lc-tech.com
1-866-603-2195 ext 103
LC Technology International
Posted on Jun 25, 2009
sunnylab85
  • 302 Answers
SOURCE: flash drives are not working but other usb devices are working
the flash has spoiled it can work again, because auto run that is in it has been disable.
Posted on Aug 27, 2009
Cannot format s73 jumpdrive
If using a PC, considering you have the USB driver installed (perform windows update first and install any suggested/required updates), plug in the flash drive, open the windows explorer, locate the flash drive, right mouse click on the name of the drive, a window should appear and select format with a left button click to execute.
Dec 22, 2013 | Lexar JumpDrive S73 - USB flash drive - 16...
USB flash devices don't need drivers. I believe you might have removed one or both of these drives from the PC without using the proper procedure, and the PC (or notebook) is now "confused". Re-attach one or both devices, but this time, either use (Windows) Explorer to "electronicaly" eject the device (right click, then choose eject) or use "Safely Remove Device" shortcut, usually on the bottom right=hand corner of your screen (the taskbar).
Sep 11, 2017 | Lexar Media Jumpdrive S73 - Usb Flash...
How do i use a memory stick on computer
An example on how to safe documents , photo's or data to a usb drive Click start all programs accessories open windows explorer navigate to your photos
Right click on the documents , photo's select copy navigate back to the usb drive right click select paste or select the top photo hold the mouse cursor then select the bottom photo then drag the photo's to your usb drive then drop them
or if you are downloading data or programs from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
If you need more help with this post a reply
Mar 21, 2013 | Lexar LJDS70-16GASBNA 16GB JumpDrive S70...
Can't download a 10 gb movie into 32gb lexar s73 jumpdrive. it says it's full
You must be formatted to fat32, reformat the disk to ntfs (this should fix your problem). You are not allowed to back up 4GB or more of data to a FAT32 File System.
Jan 28, 2013 | Lexar JumpDrive S73 - USB flash drive - 16...
How to install usb flash drive in windows vista?
Just plug it in and vista will automatically install the drivers for it.
Jun 30, 2012 | Lexar Twist N Turn 16GB USB Flash Drive...
How to install flash drive in windows vista
Just plug it in and vista will automatically install the drivers for it..
Jun 30, 2012 | Lexar 16GB JumpDrive TwistTurn - USB Flash...
Have windows xp I need a driver for a lexar 2.0 4GB
No driver needed, when plugged in it should just appear in My Computer. If it doesn't that means the memory stick is dead, junk it.
Jul 11, 2010 | Lexar JumpDrive Classic Portable USB Data...
Hi, My Lexar Jump drive 16GB suddenly quit working - now my computers don't recognize it when I plug it in but a red light flashes periodically- I was scanning and I have lots of images on it - can I...
Have you tried putting the flash device into another USB port? That will help me see what the problem might be.
Ryan Frame
Creative Energy Associates Technical Center
Nov 06, 2009 | Lexar JumpDrive Classic Portable USB Data...
Ido not know how to use it
Just install the driver to your computer, you can get it from http://www.lexar.com/drivers/index.html. Installation procedure can can found from http://www.lexar.com/drivers/instruct_win.html. After that, you now use you USB memory card.
Regards,
Jeep Brainy
Aug 12, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
Lexar Media Jumpdrive S73 - Usb Flash Drive - 16 Gb Logo
3,547 people viewed this question
Top Lexar Computers & Internet Experts
Colin Stickland
Colin Stickland
gggg
Dayton Computer
Dayton Computer
Are you a Lexar Computer and Internet Expert? Answer questions, earn points and help others
