SOURCE: 8-cup Farberware electric coffee maker
.There is a thermostat that controls the electric flow underneath to the heater. that is the most likely culprit. but am not surewhere to get another one. but you can easily changed with a Screwdriver. It shouldn't be more than $8
Hi, I just posted this for the FCP412 model: here it goes again.
I've had the same problem, I went with a percolator since our water is hard and we calcify the heating element within about a year. Having the FCP-412 stop working has made me angry as well.
1st, I placed an order for a P04-303 thermostat. It seems to be the correct replacement but we'll see. You can find it here:
http://www.goodmans.net/get_item_fa-p04-303_farberware-p04-303-thermostat-for-coffemaker-urn.htm
2nd, here is my 1 cent fix. Really, insert a penny under the thermostat. The delay that it takes to additionally heat the penny will increase the duration that the 1000 Watt element is on. You can experiment with other materials just make sure it isn't flammable (it's next to the element) and it is not too insulate (you want the thermostat to open the circuit some time after the start of the heating cycle (3-3:30 minutes).
Good luck.
-david
SOURCE: I have a Farberware L1360, 155C light stays on
Hi there are a few things that can be wrong. The pot is getting electric. Take the bottom off and see if you can find the broken. bobbyone
SOURCE: Farberware 155C Urn coffee maker, light is on when plugged in
Hi. There are a few things that can be broken. Take the bottom off and see if you can find the problem. Good luck bobbyone
SOURCE: My Farberware coffee maker starting making a high
Hi Farberware China pots and USA pots perk super fast. That is what making the racket. It will stop when the coffee is ready. bobbyone
