I'm having the same problem. I've check every option I can think of and the lights are still blinking. Turned it off, checked the ink & paper, checked connection, restarted computer, etc.....what can I do????I'm having the same problem. I've check every option I can think of and the lights are still blinking. Turned it off, checked the ink & paper, checked connection, restarted computer, etc.....what can I do????
AnonymousFeb 27, 2008
printer not responding 1 green light flash followed by 6 orange light flashesprinter not responding 1 green light flash followed by 6 orange light flashes
NO BJ Cartridge
Orange
6
Re-install cartridge or replace ityou probably don't have the ink cartridge installed correctly. make sure it is pushed and seated properly.
Here is how: 1. Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Continue to hold POWER & Press RESUME twice then release both power & resume
5: When the indicator lights steady, press RESUME three times. The indicator
should be orange.
6: Press Power to set data
Probably your waste ink counter. Should be cleaned or replaced before
resetting but usually you can get away with resetting once. 1. Start with printer OFF 2. Hold down RESUME and then hold down POWER 3. Release RESUME 4. press RESUME twice, then release POWER 5. let green light blink until printhead has finished moving. 6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960) 1 press - orange light - EEPROM info print 2 presses - green light - EEPROM initialise 3 presses - orange light - reset waste ink counter.
Hi Try this see if work for you. Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above, 1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal.
Try resetting the printer like this Canon S450 Printer 1: Power off printer 2: Hold Resume button then press and hold POWER, the beeper will sound once. 3: Hold POWER and release RESUME 4: Press RESUME twice 5. Release Power button 6: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange. 7: Press Power to set data
1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal..
canon
