My machine will grind and grind away, but never gets to the brewing. After about 20-30 seconds of grinding the machine simply stops. When pressing the brew button again, the grinding begins again, continues for about 20-30 seconds and then stops. It never gets to the brewing. Now, when I turn the machine off for about 10 minutes and then turn back on again, when pressing the brew button, the machine skips the grinding cycle and immediately goes to brewing. Then, if I press the brew button again, it once again immediately goes to brewing and skips the grinding cycle. It seems to repeat this about the same number of times I had previously pressed the brew button and only experienced grinding. For example, if I had previously pressed the brew button 7 times and only experienced the machine brewing, then when I turn the machine off and then on again, it will skip the grinding and only brew 7 times, before beginning to grind again. Thoughts?
SOURCE: Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
