SOURCE: I need to enable AHCI
Hi Jordan,
You should be able to access your BIOS setting when you first turn on the pc. The first screen you see will tell you (briefly) to push either the Esc button, or F8, F12 to access the BIOS setup. Once your in the BIOS you may have to hunt down the control your looking for but the options are not that many and you should be able find it within a few minutes.
Word of warning, by changing settings in the BIOS, you can cause your pc to act much differently or not even boot up correctly. So if you enable the Advanced Host Controller Interface (AHCI) and it does not act like you want it to, you can always change it back.
Hope this helps
