Light, turntable, and fan work if the control board is bypassed
Follow this test and fix it. God bless you
SOURCE: GE Microwave JE2160 does not heat
Does it make any noises that it didn't before it failed?? It could be a bad secondary interlock switch, cook relay on the PCB, HV circuit problem or bad magnetron. You need an ohm meter to troubleshoot. If you take the cover off, you MUST short across the High Voltage Capacitor terminals to discharge any possible residual charge to prevent shock hazard.
SOURCE: light and fan stay on and turntable no longer work
Not sure if your model has a belt driven turntable or gear driven. The cause of your problem is most likely a worn or loose drive gear or a drive belt which is worn or has come off.
Best have this checked at your local repair shop.
Best wishes,
Graemevm
SOURCE: Everything appears to work but turntable and light on interior.
It's probably your bottom door switch. See this helpful file.
You can
download GE
owner's manuals and installation instructions here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
