My Kenmore Ultra Wash model 665.1329 from 2012 is only a year old and we ran the cycle last night, after cycle was complete I went to unload it and the door would not open, the panel buttons all still work, but the door seems locked more so on the left hand side. I've pulled the power for 1/2 hour and plugged back in thinking this might reset but no luck, can anyone please help??
SOURCE: Kenmore Ultra Wash Dishwasher: Lock On Button Issue
Have to hold the Air Dry button down til your finger hurts. Release button and the light will go off. The "4 second press" in the manual is incorrect!
SOURCE: Dishwasher won't start
Drhook65,
Welcome,
I'm Huuum
How old is this dishwasher and the complete model number is?
You said, you have a Kenmore Ultra Wash dishwasher, and you have power running to it, but
when you shut the door on it...it still won't start a cycle. Does it have a reset button on
it? Any ideas on a solution?
Yes, you may try this to reset the system.
Go to the breaker and switch it off for 5 minutes and the on and try it. It usually resets the systems.
Let me know ho it goes. Huuum
Do not forget to leave a rating.
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
SOURCE: Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
I don't have the "air dry" button, just heated dry?
