No device found after connecting cd player
SOURCE: Finding AV channel to connect DVD to TV
first check if you are plugged in the right place,(you're tv as 2 a/v inputs).then you should be able to acces a/v by the menu button on you're remote,or even on the t.v. itself.well good luck then buddy,hope this helps.. btw,are you plugged in a/v (yellow,white,red) style,s-video(1cable)style,componentstyle(green,blue,red).check that out man!
SOURCE: I have a vcr and a playstation connecting to a
just lick it about 5-7 times then **** slap it and if that fails just stick it up your *** 4 times and it should do the trick hun ;)
SOURCE: step by step instructions for
Here is the owner manual that will tell you how to hook up external components to your TV.
http://www.hdtvsolutions.com/pdf/DP32746_5066--manual.pdf
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
