Question about Proton MM2701VT 27" TV
2001 Samsung 30" analog TV picture dim, max brightness = rolling
Seldom used analog TV now is pretty dim. Almost unviewable in the daytime. Turning up the brightness to the max works until a commercial is on then the screens roll.
Will turning up the flyback transformer give the relief I'm looking for or is this a symtom of other proportions ?
Given it's 30" size, I thought I'd ask first and dibble later.
2 Suggested Answers
SOURCE:
  • 1694 Answers
SOURCE: 36" Mitsubishi tv rolls
Please provide Model # and mo / yr off back of set and I can help you...................T.
Posted on Jan 03, 2008
The display panel LCD light has gone dim on my Samsung model SMH2117S. How do we fix it to restore its brightness?
1st sep go to menu,setting,picture and go brightness colloms rediuse the dim full line if not may be your screen is damage you can by new L E D tv.this old L C D tv panel is too much cost
Feb 07, 2018 | Samsung Computers & Internet
Picture dimmed. can see the picture and in menu increased the backlight to max but did not go back to normal. checked eco settings and did factory reset. still very dim but can see the picture.
Yah kindly follow this tip. After loosing the back cover when the tv power cord is removed from power socket, check for bulged or defect power capacitors in both the primary & secondary side of the power pack if found any kindly replace it with the actual or equivalent value as this electrolytic capacitor defects is much common for Samsung power packs
Apr 04, 2016 | Samsung UN46EH5300 - 46" LED-backlit LCD...
I have a Samsung 55in curved TV. It has auto dimming. In the evening with the lights out it dims to where it is difficult to see the picture. Can I get rid of the auto dimming?
If the brightness on your TV changes automatically (randomly dims and brightens), you may need to adjust the:
  • Eco Sensor function.
  • - And / Or -
    • Energy Saving function.
    The Eco Sensor and Energy Saving functions adjust the brightness of the TV to reduce power consumption.
    • When you set the Energy Saving function to Auto, the TV changes its brightness automatically depending on what you are watching on the TV.
    • When you set the Eco Sensor to On, the TV changes its brightness automatically depending on the brightness of the room.
Oct 18, 2015 | Samsung Televison & Video
My husband complains that my tv lights up our bedroom too much when the lights are off. What brands offer an option to dim the screens?
Some offer different picture options where you can preset the brightness, contrast etc to personal preference---that way set if for nighttime on the personal preference picture and normal for daytime.
Dec 12, 2012 | Televison & Video
Samsung dlp 1080p picture is dark and brightness control is at max
I am hoping somebody will answer this because my TV is dark and I played with the controls and it is still dark!
Sep 24, 2012 | Samsung HL-S6187W - Rear projection TV -...
Ln55c650 keeps flashing bright to dim very fast after about 30 minutes of being on if i shut it off for a few minutes it goes away til about 30 minutes the picture never goes away just gets bright and dim...
I had the same issue occur on my ln55c650 (screen flickering, not the actual image but the front lights flashed which was too distracting) and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Jul 22, 2011 | Samsung LN55C650 TV
My high beam switch won't stay clicked onto bright lights I have dims - but the lever won't keep my brights on. I can hold the lever forward and I have brights - but when I release the lever, I go back...
Try turning the headlight control knob clockwise so that the arrow is pointing up. You may only have it in daytime lights mode and not actually in headlight mode.
Dec 24, 2010 | 2005 Volvo S60
Picture (video) jumps from bright to dim
I figured it out myself. R243 was intermittently open. Replaced it, and now we can watch the Super Bowl.
Dec 19, 2008 | Toshiba 50H72 50" Rear Projection...
Picture is very dim
there is a problem in the flyback section of the tv set. the fly back has two knobs, one for screen and the other for focus. use the screen knob to adjust the brighness. if it did not help, either check the capacitors around the flyback or change the fly back with a new one. good luck
Jun 01, 2008 | Televison & Video
Screen too dark even with all brightness settings set to max
The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak is set is old. good luck
Sep 21, 2007 | JVC AV-27430 27" TV
Proton MM2701VT 27" TV Logo
67 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
