Vertical scan output section fault. Contact any service technician, to replace the damaged component/s. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
SOURCE: Sony KV-27V36 27"
sounds like you got a vertical foldover and could possibly be the vertical output IC but most likly its one of the waveshaper capacitors. This repair is one that alot of repair peeps swap out caps one by one to find the defective one and some use a cap checker but the right way is to use a scope to see the waveform aplitude and the shape of the waveform. This is not a user repair as this set will get repaired down to the componet level as np boards toreplace except for the sound. Take into the shop if you dont mind spending an average of 75 to 125 bucks for this repair Good luck
SOURCE: half a screen
problems on the vertical section I can do it for $ 180
we need to replace the vertical integrated circuit and poblably some caps
SOURCE: I have a Sony FD
The set has a vertical deflection problem, the vertical ic and a few capacitors will need to be replaced to restore the tv to normal function.
