Question about New Bright 384 Holiday Express Animated Electric Train Set
Np power to train the engine wheels seem to be locked
I have the 383.5
How to replace rubber wheel rings on a bachmann 0-6-0 ho scale steam engine
carefully remove the drive rod from the wheel, slip traction tire on the wheel and into groove in the wheel, replace drive rod. play with your train!
Feb 03, 2014 | Bachmann Ho Scale Trains Steam Engine...
Lionel alaska railroad engine 71
Without seeing the proper Lionel manufacturers stock number, like 25345 for example, it is hard to debug.
Jan 18, 2014 | Crafts & Hobbies
Strasburg steam locomotive receives power, but does not move.
Try cleaning the track AND wheels with an INK ERASER. Put the engine on the track and help it along. It could just be tight from sitting in the box. I live about 8 miles from the Strasburg railroad and have 2 relatives working there. We have ALL experienced the same thing on4 different sets. It isn't just the Strasburg sets that do this, it's most of the new toys. Your Strasburg cars might not connect to other train sets. Their car couplings are different, just like on their real trains.
Dec 13, 2012 | Toys
2005 JAGUAR XJ8 WONT START
Hello
The engine and automatic transmission in this vehicles drive train are fully electronically controlled by a computer called the PCM (Power Train Control Module). Whenever a problem like this occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPEDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM
Jul 24, 2012 | Cars & Trucks
One of the engine wheel is rotating but other wheels seem to be stationary. The engine thus slides along for a bit and then stops. It is a ho scale model
If you are the original owner,send it back to Bachmann
for repair or replacement..
Contact Bachmann Parts & Service :1- 800-356-3910
May 26, 2011 | Bachmann James The Red Engine Train Set
We are having difficulty turning on our New Bright Holiday Express Animated Train set. Husband and I have been trying to figure this out for our eager 2 little boys. The remote seems to turn (red light)...
Here are a couple of resources from New Bright:
http://www.newbright.com/public/electric-train-faq
http://www.newbright.com/images/Manuals/384%20ws%20manual.pdf
There is no On/Off switch on the train. Power goes from wall plug to transformer, then from transformer to track clip, which must be attached to the track. A control line goes from the track clip to the controller. Mine has a green light just above the red On/Off button that will come on even if the engine and tender are not on the track. The tender does all the work, and must be connected to the engine and on the track. There are four sliding contacts between the tender wheels that provide contact with the track.
Dec 09, 2010 | New Bright Small Holiday Express Train
I have an 1976 steam loc. and the wheels are just locked up ! What can I do to fix this?
if possible try useing some graphite/or dab a qtip in some liquid wrench and carefully touch it up till you feel some movement.
Oct 13, 2010 | Bachmann James The Red Engine Train Set
Hi, I own Toyota Emina Estima TD permanent
There may be more to it.. Transmission- P.T.O(Front wheels)-Rear Differential(Rear wheels). Or may have Transmission-Transfercase drives front differential(Front wheels) and rear differential(Rear wheels). So if one was rebuilt there should still be another that is still the root of the problem. Find out what exactly was rebuilt.
Apr 19, 2010 | 1996 Toyota Previa
Tyco trains are set up have power but trains will not move
Check the engine and transformer by taking the two wires from the transformer and, while holding the engine upside down put on wire against one side wheels and the other wire on the other sides wheels...that will tell you if the engine is at fault.
Jan 28, 2010 | Tyco Ho Vintage Wm Flat Car W/ Tractors...
Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Dec 14, 2008 | Lionel Cw 80 Transformer
New Bright 384 Holiday Express Animated Electric Train Set Logo
77 people viewed this question
Top New Bright Toys Experts
Colin Stickland
Colin Stickland
Jonah Oneal
gerry bissi
Are you a New Bright Toy Expert? Answer questions, earn points and help others
