Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W Logo
A
Andrea Posted on Dec 08, 2013
Replace thermostat compressor
How much is the thermostat compressor
juan mendez
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 36 Answers
  • Posted on Dec 12, 2013
juan mendez
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
36
Questions
Helped
15191
Points
52
Usually about 500 to 700 $ if it's the compressor the thermostat is way cheaper and there's no compressor thermostat it's one or the other
Why My haier model hcm070la Chest freezer the compressor is not kick on
check thermostat, or relay on one side or back cclose to the compressor area there is a removable lid. removed and look for a thermostat disconect the 2 wires and bridge them then plug the the freezer on if runs replace the temp thermostat for a new one should be freezer thermostat
I have a baumatic fridge freezer whch appears dead the plug fuse is ok and the electroic panal has been tested ok any ideas
Hello, Kindly check below matters on your freezer:
1. Compressor for defective. Please check the sound compressor, if still normal check the refrigerant . Please top up the gas if needed. If it is totally dead, you need to replace it with new one. 2. Thermostat for malfunction. This part will trigger the compressor to running and stop. You can test its operation while your compressor working normal. If your compressor is defective, the thermostat will not work. So please fix the item #1 before you go the latter item.
Regards,
Feb 02, 2011 • Freezers
2helpful
Red light staying on and freezer not freezing
A freezer is great for storing additional food that may not fit in your fridge freezer. If your freezer stops working, it's important to be able to troubleshoot it quickly so that food waste is kept to a minimum. Keep the following tips in mind if your freezer stops working.
Inspect the Relay
The relay is a component that helps power the compressor. It is housed in a plastic box with the motor terminals and the overload protector and is connected to the Compressor; the relay is the largest component in the box. Closely inspect the relay and make sure it is not burned out. The relay can also be tested using a multimeter. If you see any signs that the relay has shorted out, you'll will need to replace it. If the relay makes a rattling sound when shaken, this is also a sign that it has shorted out.
Examine the Compressor
The compressor is essential to the performance of your chest freezer. It is the motor that powers the entire cooling system and if your freezer has ceased to work, you need to check it. This unit is located at the back of the freezer and sits in plastic housing; it can be identified by its football shape.
You can tell that the compressor is broken if your relay is fine or if you hear a light hum followed by a clicking sound and silence. If your freezer is relatively new, it might still be under warranty and you could get a replacement compressor for free. If not, your compressor will need to be replaced by a professional.
Investigate the Thermostat
The fact that your chest freezer is not working could be down to the thermostat. This is the unit that regulates the temperature inside the freezer. To test your thermostat, remove the access panel on the side of the freezer. Next, use a screwdriver to remove the actual thermostat from the inside wall but do not disconnect the tube that runs from the unit into the freezer.
Set the range scale on Rx1 on your multimeter to test for continuity. If your multi-tester reads continuity, your freezer problem lies in another spot. If your multi-tester does not read continuity, it means your thermostat is not working and you will need to replace it. Remove the tube from the old thermostat and attach it to the new one. Screw the new unit into place on the freezer wall and make sure the tube is not coiled or kinked as this will prevent the new thermostat from working properly.
Hope this helps......
1helpful
Compressor kicking on and off now not anything
Make sure you have 120volts at relay if not jump out thermostat if it starts to run and stays running Replace the thermostat. If you have 120volts at relay and it is not running or it's kicking off and on replace Start Relay/Overload but a bad compressor can make a Start Relay go bad so if you have the same Prob. after replacing Start Relay/Overload Compressor is bad
3answers
Freeezer with no compressor activity
If all fans are running, but not compressor You could try to install 3 N 1 start kit, thats might help 50/50. If it will start compressor - be ready for compressor to go out soon. might work for a year.
Frigidaire for Kenmore Freezer-Compressor won't start
Set the thermostat to the coldest and check if there's power to the compresor relay , if yes the relay or the compresor are bad (in this case replace the relay which is the cheaper first step ,but if the compresor still won't start probably is burned out) If there isn't power to the compresor put a jumper wire to the thermostat if the compresor runs replace the thermostat.
Jul 31, 2009 • Freezers
2helpful
3answers
Compressor overheating
If you've recently repositioned the unit it could be positioned in an enclosure to tight to allow air circulation or too close to a heating vent.
Also clean the coils with a broom to ensure proper ventilation. Or the thermostat is going or gone.
Jul 27, 2009 • Freezers
Frigidaire freezer not working
The thermostat may have shorted out so that it is no longer making contact to put power to the compressor. After drying out the components try bypassing the thermostat and see if it will start or make any sound whatsoever. If it does start and run with the thermostat bypassed replace the thermostat. 4-6 inches of water can also get to the relay on the compressor. Replacing the relay and over load assembly also be a good idea.
Freezer won't run
There is no reset switch. There is a thermal overload protector mounted on the compressor. Does the compressor hum and then give a click sound. If so your compressor has failed. If the compressor is cold (Room Temperature) and it does not try to run your thermostat may be bad. If so remove the temperature control and jumper the two main wires that connect to the control. Unit should be unplugged to do this operation. Insulated the wires so they do not contact any metal surface. Plug the freezer back in. If it runs and cools replace the thermostat.
Jul 01, 2008 • Freezers
Top Danby Freezers Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
Are you a Danby Freezer Expert? Answer questions, earn points and help others
