The Flash Charging icon keeps flashing an will not go off. Flash does not work as it is continuously charging
It could be the capacitor in the flash is defect, but it also could be your battery (batteries) are to low on voltage. ALthough when that happens the camera should switch of.
There could be all other kinds of defects, like oxidation of some contacts or a broken flat cable in the camera, But my guess is the capacitor does not charge to the correct voltage.
SOURCE: olympus sp 350
Are you sure you finalized the firmware upgrade procedure according to the instructions? This sounds a little like you pulled the plug a little too soon... Have you done it according to these instructions: http://www.olympusamerica.com/cpg_section/OMfirm.asp And kept the camera connected until the update was 100 % complete? If you did everything right, try reseting the camera - take the batteries out for the day, and see if it helps. if you're back to step one(the reason you did the upgrade), try the firmware upgrade again. If still it doesn't work contact olympus, and I hope you have a valid warranty. Good luck
SOURCE: No flash
it seems that the flash is not charging. the only way to fix is to show it to some repairer.
SOURCE: flash Does not work. Can only take pictures in flash-off mode
The problem you are describing is a problem with the flash charging indicator switch inside the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
SOURCE: My Olympus tough 6010 wont bring the screen on and
Hello
Thank you for using FixYa for your problem
Always check the batteries first, try another freah set but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
