Mate dropped the engel about 2 feet from ground putting small dent on corner near power inlets and now nothing works except for the internal fridge light and the little green power light next to temperature knob. It's the same when using either 12v or 240v.
SOURCE: Engel Portable Fridge/Freezer Schematic Diagram and Spare Parts
i need a schematic diagram of a fridge
SOURCE: engel mt60f compr running not getting cold
If the compresor is running and the fan motor by the compresor too, I think there's not freon(gas) in the system beacause a leak,thst could hard to find it,could be in the copper pipes joints ,in the evaporator or in the condenser,to find it you need to presurase the system with freon and look for the leak with a leak detector(electronic,ultraviolet or bubles).Also it could be that the compresor isn't pumping in that case you need to replace it.
SOURCE: My engel MT60F motor turns on for 1-2 seconds and
Looks either your thermostat is malfunctioning. If thermostat is OK then the problem might lie in loss of refrigerant gas, freon or CF4. Get these 2 items checked in the above sequence..sodeep
SOURCE: 12v &240v connections on an ENGEL COOLER
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged
into both AC and DC at the same time. The Engel is smart enough to use
the AC while available and then automatically switch to DC when the AC
is no longer working. It will also sense the resumption of AC power and
automatically switch back to AC making it ideal for high hurricane areas
and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
