Normally if a resistor has burned you will need to locate the cause or a replacement resistor will surely blow instantly in most cases? Is your model the HD52W59 RCA with the ITC222A chassis? If so let me know the resistor board location number such as RP256 etc.
sir pls dont try it your self. you should better call a repairman for it. He will if possible repair it or you would have to buy a new one. thankyou for using fixya dont forget to rate the solution
The number you gave for the resistor is incorrect. But I did find a R14705. This resistor is a 1/2W 27K ohm resistor. This part is also in the deflection circuit. This is not a good circuit to play in, and resistor do not burn up by them selfs. There is a problem somewere neir by. The part number for this resistor is 238958.
