Canon MVX20I Mini DV Digital Camcorder Logo
Posted on Jun 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Canon MXV250i camcorder has developed a recording and playback problem. The picture is breaking up all over the screen. Sometimes half of the picture shows and at other times pictures from early in the tape still remain. Have tried a cleaning tape with out success. Have tried recorded tape in another camera but it is faulty in it as well. Tapes recorded when the camera was working properly work OK in the other camera. The camera is 4 years old.
  • Anonymous May 13, 2009
    I have the same problem with my MVX250i but until now no solution. When looking at a new recorded movie part of the screen is showing older movie parts and part of the screen shows the actual scene and the borders of the picture are squared and change sometimes. I've tried other new bought tapes but without success.
Marvin
Level 3:
Top Expert:
  • Canon Master 85,242 Answers
  • Posted on Jun 22, 2017
Marvin
Canon Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29053115
Points
266281
Time for a new camcorder, you can't get parts, they do not sell to the public.
5 Related Answers
Anonymous
  • 125 Answers
  • Posted on Jul 06, 2007
SOURCE: very grainy playback
This is typical symptom of a dirty video head. this ahappens especially if you play a tape with molds. Cleaning tapes may or may not work. the effectiveness is based on: 1. If the contamination is severe, sometimes the dirt really sticks to the head. You will not normally see this because the head is the tiny part on the head drum that spins. 2. If you use a non original head cleaner 3. If you re-use a tape cleaner. I had this problem on my Sony Hi8 camcorder, i had to mannually remove the dirt on the tape head. I will not recommend to do it as it may damage the head. What I would recommedn first is to buy a Sony head cleaner, and try to clean the head. You may try more than once, it will not damage the head right away. If this does not work, before you send it for repair, ask for estimate. Maybe it is cheaper to buy an analog Hi8 player on ebay rather that send it for repair. And BTW if you have a Hi8 camera, it can play both video8 and Hi8. If you have a video8 camera, it wont be able to play Hi8.
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Jun 11, 2008
SOURCE: 8mm analogue camcorder tape playback at double speed
If you ran it through that many 8mm players, I'm going to say that the tape has something wrong with it.
You can see visually if there is anything wrong with the tape by releasing the cover by moving the tape and visually inspect the tape for anything that could be frayed. Usually you can see it on the bottom of the tape.
Sometimes the takeup can be messed up in the tape too. Once you release the tape cover, you can turn the white wheels to see if there is any slack in them.
Good luck on that.
Anonymous
  • Posted on Jun 21, 2008
SOURCE: Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Anonymous
  • Posted on Oct 31, 2008
SOURCE: Playback
Recording and playing a new tape worked for me too. Thanks!
Anonymous
  • 36 Answers
  • Posted on Mar 20, 2009
SOURCE: My Camcorder Breaks the tapes
Your camcorder needs to be cleaned and or serviced ASAP. Please do not use any more tapes, as you may have a stuck roller head or sticky contact surfaces that can "catch" the tapes intermittently.
You should be able to have it serviced very cheaply at a camera store, but I would not use it any further for danger of potentially ruining the camera.
Camcorder picture has no colour and very dark
Playback a recorded tape on another monitor such as the computer's or a TV. If the recorded program is ok, then your camcorder screen is bad. If the recording is bad, then you may have a CCD or lens problem.
Canon HV10 camcorder - can't get video mode to playback
hi, if you get blue screen,but your recording has been ok, then you must be change LCD FLAP, you sure get fix your camera,
Black screen in REC mode, bars across the screen in Playback mode
My advice is that you should by a DV cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
Distorted sound on playback, samsung mini dv camcorder.
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Wont record anything to MiniDV tape and A/D randomly working
Sorry about delayed reply as I just saw it.
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Regarding can't see picture or time code in playback, it is problem of dirty / clogged video heads. Use good quality video head cleaning cassette to clean heads and hope camera will show playback picture.
Good luck.
Recording
There is a recall on some Canon camcorders. Call Canon technical support. They will fix for free as well as free shipping. I had the same problem.
Playback not working
Hai, Clean Video Head with Head cleaning Cassatte & check the picture. udupi M/s.Prathiksha Electronics
1helpful
Playback & Ejection Problem
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
