Could hear the water running down the drain
SOURCE: toilet not flushing properly
there are allot holes around rime inside they get clogged over time because water quality very hard to get there to clean best bet replace toilet
SOURCE: tank won't fill unless I push down on flush valve inside toilet
Hello there
ok first when the valve inside of the tank is wearing out or is dirty this will happen you can take a washrag and clean the underside of themechanism really good and also the part that it rests on providing that you can get to it
if there are no screws to adjust the water reg valve see if it will turn clockwise to shorten the arm making it turn off or if needed turn it counter clock wise i have had to also slightly bend the arm down in some units to make the water stop after the tank is full so you may want to try that too ok
hope that this helps
best regards michael
SOURCE: I have a Jacuzzi Perfecta toilet (bought Aug. 21,
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Testimonial: "I took the valve apart. It is working like it is supposed to. That sure is a tiny hole for the fill water to shoot through. that is why it is so slow. It still whistles when filling. Tnx Walter Neaves"
SOURCE: We have a Jacuzzi X532 toilet. Can't get the water
I am not familiar with the model of toilet that you have, but many toilets suffer the same problem. It is usually due to the toilet cistern over-filling, as the water running into the bowl is the safety-overflow mechanism. The overfilling can be for a few reasons. The most common is that the fill valve is being held open, either due to mal-adjustment, or due to it being postioned slightly wrongly so that it hits either the side of the cistern or another part of the mechanism and can't close off properly. If you lift off the top of the cistern and watch what happens when the flush goes, you might be able to spot what is preventing the valve from shutting off entirely, and solve it. Hope this helps! :)
SOURCE: tank won't stop filling up...overflow hose just
You need to replace tank valve.
See photo of the product:
http://salestores.com/fluidmas.html
Buy this product at hardware store.
Turn off water to toilet.
Flush toilet to empty water from tank.
Under the tank, the tank valve is held with two nuts.
Nut1 seals water line to the valve.
Nut2 seals valve to the tank.
Loosen nut1 and it drops down. You can use same nut for new valve, or use new one that comes with product.
Notice there is a beveled washer stuck in bottom of valve, or stuck inside nut1. Your new valve will have a new beveled washer.
Loosen nut2 and valve come loose and can be lifted out.
When you lift up valve, remaining water will run onto floor so have a pan and towel ready.
Notice on bottom of valve is a rubber washer. This washer seals the valve and tank together so water will not leak.
New valve comes with 2 washers > big one and small one. They are usually attached together, small one inside bigger one, and you have to tear them apart.
Clean opening of sand and dirt.
Supply pipe is sticking up.
Put nut1 and small beveled washer onto the supply pipe, with flat side of washer facing downward and rounded side facing up toward tank.
Put bigger washer on bottom of new valve. Flat part of washer goes to valve, beveled part of washer faces downward to tank.
Set valve in place and notice how washer covers the hole.
Put nut2 on bottom of valve and tighten. As you tighten the nut, valve will rotate inside tank. Make sure float and parts can move freely.
The valve doesn't have to be super tight to seal. Just tighten ia reasonable amount, and you can tighten more later if needed.
Now attach nut1 to bottom of new valve and this will seal supply line going into tank.
This nut has to be fairly tight.
Turn water on.
Valve has adjustments for selecting height of water inside tank.
Use paper towel on bottom of valve to check for leaks.
Leave catch pan under new valve for couple days to make sure there is no dripping.
If water is seeping, then tighten nut1 or nut2 a bit more.
Sometimes the shut off start leaking. Open shut off all the way to see if this solves problem.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on toilet.
