Trying to connect orange livebox (upstairs) to xbox (downstairs) via powerline ethernet system . cant even get 2 powerlines to connect through orange livebox is there some config problem in orange livebox
thanks jas
M. Razaire
Try to eliminate the problem into smaller parts. Try networking the two via the same power outlet via a multiple power board first in the same room. I don't have much experience with these powerline ethernet but i'm sure the configuration of these will be very similar as wireless router / access points and wireless adapter cards. However what I do know is that your power outlets need to be on the same "phase" of your electrical power system, so if you do this test I suggest (from one outlet board) you know the equipment works and your setup procedure works. then try seperating again and if it still doesnt work, check if your power outlets are wired on seperate phases (depends if your house has 3 phase wiring incoming to your home or not). Try another room or another outlet.
