Espresso is not dispensing fully even though there is pressure. i believe theres a clog between tank and spout
It's probably clogged up with hard water deposits. Fill the water reservoir with plain white vinegar and put the espresso pot in place as usual, but do not load coffee! Run as usual for making espresso.You may have to run a couple of tanks, until the vinegar is pretty much colorless. Then run a couple of tanks of water to flush the vinegar. If your machine has a steam valve for frothing milk, put the steamer pot under it and open the valve as well. Over time, the steam valve can clog up with milk solids, called casein, which is actually a form of organic plastic.
If you can get steam/water from your steam spout.
Fill your tank and add descale solution.
Descale according to the instruction for the unit.
After descale and rise are complete refill your water tank.
Your system should now work as normal.
Note: If you do not have a descale solution, run the above with just water. Remember to descale when you obtain a descale solution.
