After the woofer has been on for a few minutes, it begins to make a loud thumping noise that continues until I shut it off. If I let it go, it seems to continue for a few minutes, then stops for a while, then happens again. Any ideas why it is doing this?
Remove the signal source and power it on to see if the problem occurs without any input signal. The problem could be in the receiver and not the sub
I unhooked the line-in, and turned the unit on. After a few minutes, the thumping sounds returned. Eventhough it didn't work, I didn't think about it being a receiver problem. What should I try next?
it appears that something is wrong with the amplifier in the sub. You'll probably have to send it out for repair.
