Oven bake stays at 100 and would not heat up. broiler and gas top is working fine
SOURCE: We have a Maytag Gas Range, Precision Touch
Likely your oven igniter is bad. Part number 74007498
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
Sounds like your oven igniter is bad.
Part number is 74007498
SOURCE: top oven not heating up on BAKE, broiler gas and
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
SOURCE: Top oven works fine on broil and bake. Bottom
Hi
This means a loose/broken wire on
the oven temp sensor or the sensor is bad and should be replaced. To solve this
issue start by checking the oven temp. sensor for 1100 ohms, if the rating is
more then that then check the control and door switch and replace the part that
is bad. Hope this helps...please post back for further assistance.
Daniel
