Hello. I have the Cuisinart DCC 1200 and it has stopped working. I customarily set the first dial to Brew, and merely flip the power switch to On, and that does the trick. However, when I do this now the Power light turns on and nothing happens. No sound, no brewing, nothing at all. Might there be a solution within easy grasp? Thanks so much!
I don't know if this is the same as a regular coffee maker but here is the answer I gave to another guy. I am not responsible for anything you choose to do if you do it yourself. Here goes:Inside the coffee maker , you will find a horseshoe shaped aluminum metal water heater. This is the part that transfers the water from the container to the part just above the pot using a plastic tube. the water heats up to a certain amount and 'drips' hot water on to the coffee and into the pot.
First disconnect all the electricity and be careful and not be too rough handling the coffee maker in general.
You sometimes need special tools to remove the screws
because they are not ALL regular Philip head screws. They can be torx or a special torx screwdriver with a hole in the middle.
What I do is use my dremel with a grinding bit and remove all the screws if they are not regular head screws.
I replace the screws with other regular Philip heads.
You have to empty the coffee holder and filter and the water in the coffee maker in order to do this and remove the bottom off the carefully. it is mostly cheap plastic in many brands.
Just inside you will see a couple of electronic components that look like a little missile (lol) these things are called thermisters. Their job is to protect the rest of the components from overheating and causing something else to burn. Those are the ones that go bad when your coffee maker goes off like that. everything else is working except those little thermisters
Most times coffee are discarded because of hard water buildup inside the horse shoe ( as I will call it from now on) and it will be very slow heating the water because the water can't pass through.
I used the thermisters of an old one that I had thrown into the garage about a year before with the clogging problem. took the thermisters off that one and connected them to the one that wouldn't do anything except turn on the little light on.
(There are some you can buy online that are switchable thermisters. Which means that they will turn off when or if the heat reaches a certain temperature.Then instead of burning out all together like the cheap ones, they will cool off and turn back on when they cool off. You can find them at ebay from the ebay ID name of Wendell Riseley. He is quick to deliver and even includes his email and phone number if you have any problems. You just replace the missile looking ones with the new ones which are flat with 2 wires ) Please do this on your own I do not want to be responsible for anything going wrong. I am simply informing you. And with that said NOT RESPONSIBLE.
I just basically tied the good wired thermisters by over lapping them over the old ones in the coffee maker and made sure it was fairly tight. You can't use solder cause it melts down with the heat generated by the heater. which is a small little ceramic encased thing that is placed to latch unto the horse shoe on it's side.
Just be careful to put in the new ones the same direction as the other ones are. Hope this helps you.
Posted on Oct 22, 2017
SOURCE: Cuisinart DCC 2000C
We have the same intermittent problem with the on/off switch on our DCC 2000C......don't know if the switch is bad (we hear it click when turned on) or if the water pump is intermittent. Either way, the end result is no coffee and concern about a potential fire. Today, after reading a post by a DCC 1200 owner with the identical problem, I called 1-800-726-0190 and spoke with a young man who was most helpful. Although, we cannot locate our proof of purchase, we believe the serial number indicates manufacture within the warranty period. He said we will receive a replacement in 7-10 days and then we must return the malfunctioning unit in the same box along with a $10.00 check. We'll see how it goes and post again if it doesn't happen as I've described.
SOURCE: cuisinart dcc 1200 will not brew
I'lm not sure of the model, but it is a Cusinart Coffee Maker with a Glass Pot. It gets power on all lights except the ON/OFF switch, and it willl not brew. Any suggestions, or should I trash it and get a new Coffee Maker. This one is approx. 1 year old. Thanks for your advise.
SOURCE: I have a cuisinart coffee maker. I can set the
Unplug the coffeemaker for 20 minutes or longer - not a second less - in order to fully reset it. Then, when you plug it back in, turn the function dial to Clock again. Press and hold the HR button for a few seconds, and then set the hours. It should work now unless it got zapped, as you said.
-Tha Mp3 Doctor
SOURCE: Cuisinart DCC-1200 brewing temperature
Hello ditommm,
Not to worry, I think I can help. On the face of your DCC-1200, there are two black switches. The right one adjusts the carafe temperature. With the white line to the left you get a lower carafe temperature. With it all the way to the right you get the highest (hottest) temp. Of course, in the middle, you get a medium temp. I use mine with the lowest temp so that I don't end of scalding my lips and tongue when I drink my coffee. Use this bit of info to adjust your carafe temps. If you are looking to cause the actual brewing temp I don't know of a way to do that. Coffee needs to be brewed at the set temp in order to break down the elements of the ground coffee. I hope this is what you were looking for in an answer and that it is helpful. If it is, please consider leaving positve feedback for me. I will certainly appreciate it. Good luck! Regards, NormanZ
