I have a samsung smart wash b1245s washing machine.last week i was using it and it stopped working.
i tried to restart and didn t want to go.
the day after i tried to put it on and strange enough it started .... i tried all the program and it seemed ok.
However after about 25 minutes when the spin started machine stopped again. and didnt want to go further.
I cleaned the filter tried again and it started, tried all the program and it looked ok. .....then stop again.
Behind the eletronic panel you could hear a little sound like when two cable are not touching properly and do a sound like zzzzzzz.
i removed the cover checked all the little plugs and i started the machine with the spin program.
it finished with no problem. fine let s put the clothes accumulated in a week....
when the spin was half way showed the error DE (door open) but in a second disappeared and the machine went on by itself, then after few minutes after again same error appeared and machine stopped.
tried to restart again but now it won t start at all and show me the error DE.
i disassembled the door circuit cleaned (it was like a little short circuit appened) but machine sitll show same error and doesnt start.
is there anyone that can tell me what is wrong?
Motor brushes are worn and nead to be replaced easy job if you turn washer on to its side remove the 2 screws at the bottom and take off the plastic panel you can see the motor and the brushes are red plastic bits remove them and replace with new ones that should sort out the problem and cost about £25.00 to do .
Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Same error DE
I am having the same problum with my machine .Kindly guide me regarding my problum .
The filter has been checked and clean. The washing machine washes until second last step and then again gives E-05 error. Can you show me how to clean filter and tube.
