Question about Sony DPP-FP50 Thermal Photo Printer
Need driver driver for Sony dip-fp50
    Guru:
  • 377 Answers
You can download your driver form this link
http://esupport.sony.com/p/swu-download.pl?mdl=DPPFP50&upd_id=2611
hope that it helped
Posted on Feb 18, 2014
6ya staff
SOURCE:
Sony DCR-HC40E when turned on using battery (NP-FP50) power will display the following mesaage "Use InfoLithium Battery Pack" and then switch off.When on DC power it works fine. Also, when I...
It means the camera has detected that the battery is not genuine or not compatible. sony batteries has the data chip that provides the 'info' in infolithium.
check with the vendor who sold you the battery.
Sep 21, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
Need driver update for Windows 7 - 64 bit. Is there one?
The Sony Support site does not list a driver for either Vista or Windows 7 (neither 32 bit nor 64 bit). If you have Win7 Pro or Ultimate, you can install the XP mode and load the driver for this printer on to that virtual machine.
I hope this helps.
Jan 06, 2010 | Sony DPP-FP50 Thermal Photo Printer
The manual that came with my printer is not in English
You can pick out the manual or guide you want here:
http://safemanuals.com/zearch_652.php
Enter your model number in the search window on that page:
DPP-FP50
Oct 14, 2008 | Sony DPP-FP50 Thermal Photo Printer
Operation
if you power the camcorder from the call socket, if it works that mean the battery has bad.
May 12, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
TROUBLE PRINTING
These are following cases for this symptom.
If the access indicator flashes in green:
The data size of the image is large and it takes longer to process it for printing. Printing will start as soon as the data processing finishes.
If the paper error indicator flashes on the LCD:
The paper is jammed. Turn off the printer and turn it on again, take out the paper tray, and then remove the jammed paper from the paper outlet. If you cannot remove the jammed paper, consult with your Sony dealer or service facility.
If no indicator is lit or flashing:
The thermal head may be overheated. Leave the printer until the head cools down and the printer resumes printing.
May 11, 2008 | Sony DPP-FP50 Thermal Photo Printer
Battery Charge Light not working & can't display battery info
This sounds similar to a problem I had. I brought the camera in under warranty and the repair shop fixed it. They shop text is cryptic.
Problem: Camera light keeps flashing, not charge
Solution: Troubleshoot to intermittent switch block control, replace with new one, test OK.
Dec 29, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Printing problem
you may have a faulty Thermal element, sounds like a cold spot in the middle of the print head is messing up your photo. If this is in warranty or is new get them to replace it
Aug 22, 2007 | Sony DPP-FP50 Thermal Photo Printer
New batteries will not charge
a technician ' s adjustable bench power supply - set for 9 volts at 1 amp - for a minute or so , will initialize most new lithium batteries ( a charger update may also be available ) ;
Sep 18, 2006 | Sony Handycam DCR-HC30 Mini DV Digital...
Sony DPP-FP50 Thermal Photo Printer Logo
73 people viewed this question
Top Sony Office Equipment & Supplies Experts
Jaime Hernandez
jasbo
jasbo
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
