I just purchased the system, went through the basic operating instructions and enjoyed 1 cup of coffee. Now I can't get past the "fill system/rinse" message. I hit the rinse button, the system makes some slight noises but no water comes out of the spouts....and the message "fill system/rinse" remains.
SOURCE: leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following:
1) take of the warmer plate on the top - 2 storz screws but an allen key works as well
2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess
3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front
4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly.
5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely.
6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free
7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel.
8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece.
9) You will now see the plugged spouts.
It goes back together really easily.
SOURCE: Jura S9 Capresso Machine "Fill System" Message
I think you use too fine grist on the grinder, or the coffeebeans are really dark and moisty. Try to set the grinder to a coarser grist, for dark roasted coffee it`s not recomended to to use any finer than medium grist. However, the sieve in the brewing unit could be clogged, and you need to clean this out. Put a finger up in the brew unit just along the grounds blade, you will probably find a lot of old fine coffeeground up the. Clean it up as best as possible, and then try to make coffee with coarser grist. If this helps, it`s smart to run a cleaning program to be on the safe side.
If nothing of this helps, you don`t have a choice, you have to send it for service, then the brew unit has to be dissasembled and cleaned from the inside.
SOURCE: Fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
SOURCE: Jura S9 coffee machine not drawing water - says FILL SYSTEM
I think the magnetic valve is defective. This is located on the left side (seen from behind inside the machine) and there`s connections between the thermoblock and the hot water outlet. Try to press the steambutton and check if the magnetic valve clicks, and maybe check with a voltmeter if it`s receiving power.
PS. During steamprocessing the pump just have small ticking sound, and not the same sound as during brewing. There is no way around this Fill system message, and the reset function is not activated until any System Messages has been clared.
SOURCE: I can't get past the 'open tap'/'close tap prompts on my Impressa
I had this problem with my Ena 3. The difference was that water was actually passing through the nozzle, but when I turned the dial back to the coffee symbol it would just tell me to open the tap again.
The solution was simple thanks to bergend's post, although I'd never have thought of it independently. I emptied the water tank and filled it back up with luke warm water instead of the cold water I had been using. After the first "system filling" round, the machine continued with the setup program fine.
So, to others with this problem: don't use too cold water in the tank for the first setup, even though the manual tells you to. Luke warm works great.
