SOURCE: machine smells mouldy- washing stinks!
Find out where your filter is; it is at the end of the thick hose coming down from the bottom of your tub; open up and clean out. Another possibility is there could be something stuck in your drum, feel if you could locate it. Next clean out the hoses in machine. After all this flush out with a hot wash, without clothes. People shd ask the service man where the filter is. If he knows that is.......................It gives you the biggest problem if you dont check.
SOURCE: My washing machine is leaving powder/liquid all over the clothes
you're using too much detergent
SOURCE: smell while washing only
Like bad eggs ?
Do you have a U bend in the wastepipe that takes the water away from your machine
If not then any smells from the pipe run can come back up the outlet pipe
Once you have ran the machine it flushes away the old water and the smell goes away
SOURCE: Clothes and towels don't smell fresh after washing
If you are sure that the pump is not blocked then try running the machine on a quick wash on its own with a little bleach in the drawer.
