SOURCE: trying to install videocam suite 1.0 on xp home edition
Try right clicking on the installation .exe and clicking Properties. There might be a tab that says Compatibility. Click that and choose XP or XP/SP2 from the list and press apply.
try running the install now..
Hope this helps
Season's Greetings!
chris (ziraffa)
PS Here's the updater file for Videocam Suite too, which will be handy if you do manage to get it installed...
http://panasonic.jp/support/global/cs/soft/download/videocamstuite_v10.html
SOURCE: I have SDR-H60, installed the videocam suite on my PC but cant us
The software will work only if you attach the camera to the electricity cable comes with the camer...The software will not work using the battery.
SOURCE: The VideoCam Suite 2.0 supplied with my Panasonic
Successfully got the VideoCam Suite running on Windows 7 Ultimate 64-bit. Step by step instructions follow.
Insert the program CDROM.
Don't use autorun - Cancel autorun popup.
Right click on CDROM drive in "My Computer" and select 'Open'.
Right click on Setup application & choose 'Troubleshoot Compatibility'.
Select 'Troubleshoot program'.
Select "The program worked in earlier versions of Windows but won't install or run now' & click the "Next" button.
Select 'Windows Vista (Service Pack 2)' & click the "Next" button.
Click on "Start the program..." button.
Installation will start.
VideoCam Suite will probably be flashing on the taskbar so select it.
The window will show: 'This application does not support this 64-bit operating system. Are you sure you want to install?'
!!! Click the "Yes" button !!!
Proceed with program installation.
When installation finished cancel out of the 'Program Compatibility' window.
Panasonic VideoCam Suite 2.0 works just fine on my laptop.
SOURCE: non compatible with windows 7
Version 2 is compatible with Windows 7:
http://panasonic.jp/support/global/cs/soft/download/vcs20ee_w7.html
