Which buttons do i use to change and set the time
SOURCE: Women's Timex Rush Sportwatch
Try holding all of the buttons down at the same time and then releasing them. This should reset the watch. If that does not work, then you need to take the back cover off again and briefly create a short (with a metal screw driver for example) between the battery and the 'brass' casing. Hope this works for you!
SOURCE: Setting Timex watch
Since you have changed to the newest program I cannot get in the watch program I was using to set the watch. Please help.
SOURCE: timex 1440 sports digital watch time setting
SOURCE: changing time-for day lights saving time on watch
A. Press and hold MODE until HOURS digits flash (you’ll be in Alarm Mode). Press MODE again
to enter TIME mode. SECONDS digits will flash.
B. Press ADJUST to set SECONDS to zero.
C. Press START/STOP to select MINUTES.
D. Press ADJUST to change.
E. Repeat to set HOURS, MONTH, DATE, and DAY of WEEK. Go through 12 hours to set AM
or PM.
F. Press MODE when done.
SOURCE: howw to change the time on a timex watch
As you did not submit any numbers, I can't help, but you can go and visit this site:
http://www.theusermanualsite.com/manuals/mfg/timex/
Register and find what you want.
Do not forget to rate, please.
Whatever Kind of Watch You Have, We Likely Have a Battery for It!
www.Duracell.com/watch-batteries
