Compaq Presario 4410US (470027-053) PC Desktop Logo
Posted on May 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The front USB port is not working, when i have to sync my iPod i have to go to the back of my computer, and it's really annoying to do. how do i fix my problem?
Anonymous
Level 3:
President:
  • Master 2,653 Answers
  • Posted on May 11, 2009
Anonymous
Master
Level 3:
President:
Answers
2653
Questions
Helped
744382
Points
7663
Did they work before?
1helpful
How do I delete songs
More info please. Without it I offer this.
Have your iTunes on your computer. Open iTunes and update your music. i.e. delete the songs you wish to delete. Then set your iTunes to sync to your iPod (make sure you don't have it set to sync the other way). With iTunes open, plug your iPod into a USB port and the computer should sync back to the iPod and mirror your iTunes files.
Charger ipod model a1199
http://www.everymac.com/systems/apple/ipod/specs/ipod-2nd-generation-nano-specs.html
USB Support:
Sync & Charge
Firewire Support:
Charge Only
Details:
The second generation iPod nano models are capable of charging and syncing by USB via the dock connector. It also can charge, but not sync via Firewire "400".
Connectivity:
USB
Ports:
Dock, Headphone*
Details:
Apple reports that this model provides "USB through dock connector."
*Ports include the "dock connector [and] stereo minijack".
http://www.bing.com/images/search?q=images+of+apple+ipod+usb+chargers+&qpvt=images+of+apple+ipod+usb+chargers+&FORM=IGRE - view=detail&id=9C41186E7131E6658B9324CCA
HOW TO SYNC MY IPOD QUICKER
you could try only syncing changes to library instead of resyncing the entire library.
also you could try using a different usb port on your computer instead of using the ones in the front try the ones in the back.
I'm trying to sync an apple ipod shuffle 4th generation to my windows xp pc. The famous USB device not recognized thing pops up. What do i need to do so i can use and sync my ipod.
Shutdown Windows.
Turn the computer off.
Unplug the AC power cord.
Reconnect the AC power cord.
Restart the PC.
This will eliminate many "intermittent" problems.
Now, connect some other USB device (mouse? keyboard? memory-stick?) into the USB port, to confirm that the USB port is working, at least for some USB device.
Now, connect the iPod to one of the USB ports.
If it is not recognized, connect the iPod to a different USB port.
This should work.
2answers
Starting up with anew ipod touch
To use iPod touch, you need:
  1. A Mac or a PC with a USB 2.0 port and one of the following operating systems:
  • Mac OS X version 10.4.10 or later
  • Windows XP Home or Professional with Service Pack 2 or later, Windows Vista Home Premium, Business, Enterprise, or Ultimate edition.
  • iTunes 7.6 or later, available at www.apple.com/itunes
  • iTunes Store account (to purchase music over Wi-Fi)
  • An Internet connection
Before you can use any of the iPod touch features, you must use iTunes to set up iPod touch. You can also register iPod touch and create an iTunes Store account.
  1. Download and install the latest version of iTunes from www.apple.com/itunes.
  2. Connect iPod touch to a USB 2.0 port on your Mac or PC using the included cable. The USB port on most keyboards doesn’t provide enough power. Unless your keyboard has a high-powered USB 2.0 port, you must connect iPod touch to a USB 2.0 port on
    your computer
  3. Follow the onscreen instructions in iTunes to set up iPod touch and sync your music, video, photos, and other content. Your computer must be connected to the Internet. By default, iTunes automatically syncs all songs and videos in your iTunes library to
    iPod touch. If you have more content in your library than will fit on iPod touch, iTunes alerts you that it can’t sync your content. You’ll need to use iTunes to select some of your songs, videos, and other content to sync.
When you get back to France, you'll need sync it with your PC. Download the latest version of iTunes then sync your iPod with your computer.
Ipod 8g wont sync
There are several possible reasons:
1. You have damaged the USB port of your PC. Try in other USB port or other computer to check if the Ipod is recognized.
2. The USB cable is damaged. Try another one.
3. The ipod has either damaged the main board or the dock connector port. Ther is not solution but replace the damaged part and it needs to be done by somebody that knows how to do it.
4. Sometimes the dock connector port is dirty. Using a magnifier with light, you can check if this is the case. If so, blowing compressed air will remove the dust and dirty, or if there is something liquid (such coke residues), you can use a dry and clean rag or napkin will do the work, but you have to do it very carefully so you won't bend or damage the metal contacts.
Best regards,
Suddenly my pc re-boots when I plug my ipod into the front usb.
uninstall service pack 3 and ignore it when it asks you to re install it. go to add remove programs and uninstall it. obviously it worked befor. that is the solution. you dont need sp3 anyway.
2answers
Apple Ipod isnt recognized on computer
You can only sync one ipod with one computer so if you put music on it already it will only work with the original computer you synced it with. Same with ANY ipod.
3answers
Ipod nano 4G silver not syncing
Try pluging in the iPod and when it does not sync press F1, this tells the computer to update any USB port but usually doen't work. Then try reseting the iPod while plugged in. You do this by holding the Menu and Middle button for five seconds. Also go into my computer to see if your iPod has shown up there. I think that a 4th Gen Nano would still be under warrenty. Make an appointment to the Apple store's Genious Bar. If it doesn't sync there, they may replace it.
Ipod nano 1st gen sync/charge problem
Try these options i got them from apple when my ipod dident work trying a new port and reinstalling itunes worked for me 1)Reset your iPod. 2)Retry with a different USB or FireWire port. 3)Restart your computer and make sure you have the latest software updates installed. 4)Remove iTunes software and then reinstall iTunes software from latest versions on the web. last resort 5)Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
